[Z06] Lets See your aftermarket valve covers
Now that my build is running, would like to work on the engine bay appearance. Will likely shave and paint my MSD intake manifold. Also considering doing a coil relocation and running these valve covers powdercoated:
http://www.ebay.com/itm/LS1-LS2-LS6-...VYri2N&vxp=mtr
Question is, what are you guys doing for the Oil sump breather lines that hook into the valve covers? Replacing with another style of line?
Lets see some pictures of nice aftermarket valve covers and coil relocation!
Popular Reply
04-05-2017, 04:57 PM
Premium Supporting Vendor
Thats the thing. I refuse to pay corvette tax prices for valve covers and coil relocate just because they are katech or vengance racing or whatever. Some people want to pay $1k for valve covers? More power to ya. Too rich for my blood. Id rather buy the ebay ones for $100 and have my painter make them a one off set that no one else has.
My plan right now is to do some sort of hydro carbon dipped valve covers, coil relocation to fenders, and paint my MSD zr1 blue to match the color that my calipers will be. Hmmmm....
/end rant
I think the Holley covers look real clean with integrated coil mounts.
Dumb question, can we use LM7 valve covers?
I've got a friend with a set of LM7 valve covers that offered them up to me so I could dress up my bay a bit but I wasn't sure if they'd bolt up.
Holley. Just silicone or rubber line from sump to appropriate spot.
I relocated my coils to where the air filter is located. If you do this, you will need to make your own plug wires. If I remember correctly, I made 8 wires that are each 4ft in length. My car is currently getting tuned but I will take some pictures when I get it back. You also need to buy the bracket and harness for the coil packs, which I bought on ebay.
Do you have a link?
RyanT (04-05-2017)
The following 2 users liked this post by MTBSully:
Frankie2blue (04-05-2017),
LoganExplosion (12-04-2017)
If you make your own wires you need the following:
MSD 34013 (2 Packs)
MSD 3503
MSD 3304 (4 Packs)
MSD 3301 (4 Packs)
I bought it all through Advance Auto Parts and used one of their 30% or 40% off coupon codes. It is relatively easy to make the wires. Make sure that yo have some WD40 to pull the wires through the boots or you will never get them on. It takes time but with a little patience is fairly easy. You also need some Velcro tape to hold the coil brackets in place.
MSD 34013 (2 Packs)
MSD 3503
MSD 3304 (4 Packs)
MSD 3301 (4 Packs)
/end rant
The following 13 users liked this post by Katech_Zach:
11GrandSport (04-05-2018),
67 327/400 (04-06-2017),
Apollo29 (11-05-2017),
C6Z06Silverbullet (09-21-2018),
CTYANK2 (04-09-2018),
and 8 others liked this post.
CF Katech
IIRC the coil closest to the alternator can present clearance issues with the tall covers...but the D3 spacer block for the alternator can rotate it out of the way.
