Need replacement wheels for a 1962 corvette.
I purchased a 1962 basket case in a field and the wheels will not hold air.
What wheels can I use to cheaply move the vet to my garage?
Thanks in advance...
Mark62vette (05-21-2017)
Maybe have some tubes put in the old tires and wheels.
http://lugpattern.net/Chevrolet_GMC_Bolt_Patterns.htm
Doug
Tubes. Your chances of finding 4 serviceable S-10 spares in one place for cheap are zero and zilch.
2018 C1 of Year Finalist
you never know unless you try... Actually, I found three of them and one Z28 rim from a 70s model when I needed them. Worked fine at the time (2008). I tried to grab a set of rally rims but the owner of the junk yard did not want to give up the goods. A full set were sitting on the rim section and I figured they were there for a reason. I grabbed the set and took them to the counter. The owner was "no,no.no!"...
Charles
I've got 2 15 x 5 1/2 with the correct bolt pattern, riveted, not welded. Not technically correct for your car, but hard to tell a difference unless NCRS judged. Unless you plan to go aftermarket, this would get you half way there. PM if interested. But, for rollers, lots of wheels fit.
Mark62vette (05-23-2017)
The rivited wheels on my '54 leaked. I just bought some tubes (cheap) and problem was solved. Be patient when looking for correct wheels for your '62. My '62 came with two wheels off who knows what that were incorrect so I bought some repro wheels but the 4 nibs were so big the hubcaps wouldn't go on. I sent them back and almost bought the first pair I saw on ebay for way too much money. I took a little additional time and finally came across a listing with a reasonable price. Using inner tubes will allow you to be patient when searching out a correct set of wheels with the 4 nibs if that's your plan.
When I drove my car 7 days a week 52 weeks a year, I carried a pair of Firestone Town and Country snow tires on rims from my '51 Chevy in the back during the winter. All of the Chevy rims from when they changed over from 6 bolt to 5 interchanged.
Obtain a NCRS sticker , place it on the windshield, calm your nerves, a major goal lies in the far distant future.
I like the description " cheaply ". Has nothing to do with Corvettes.
Mark62vette (05-24-2017)
Received 1,901 Likes
I would bet if you go back, the wheels will still be there. You know, he's saving them for his special project that he's going to finish! LOL!
Pat
I know some who have taken the tires off and used a "sealant" type paint to the inside of the entire wheel. Kind of like the old American's that will leak at times.
Worse case is that you could put tubes in them.
Good luck with your project, you're going to have a lot of fun with it!
Pat
Hello Mark, and welcome to the forum.
Pat
Pat
Randy G. (05-23-2017)
