C7 clutch adjustment
OK Guys: I just drove a C7 for the first time and have a few questions which the salesman could not answer. First of all it was a '16 with manual transmission. I am used to clutches grabbing close to the floor. The car I drove, the clutch didn't grab until at least halfway out. These clutches on the newer cars are different than the 60's models to say the least. Can they be adjusted to grab closer to the floor? I know this question will get plenty of laughs but that is why I am here; to entertain you. Any help would be appreciated.
Clutch is hydraulic, and as far as I know, no adjustment.
My 69 Camaro had a spring loaded metal arm to the throw out bearing, but not on the new cars.
garywalsh (04-22-2017)
I had the same issue when I took delivery of my '17 6 months ago. Additionally it feels like the clutch jumps up at you right at the end of travel when it's going to engage. You get used to it. I did and love it. Two days on the track at Spring Mountain Owners School helped a lot too.
Halfway is exactly where it should be. Old-school clutches grabbing close to the floor were a prescription for wearing friction plates out quickly, because they often were not fully disengaging from the flywheel.
The following 2 users liked this post by Foosh:
garywalsh (04-22-2017),
Perf n Restore (12-06-2017)
No adjustment on the Corvette. I hate that it grabs low high. My M3 has a pedal stop so you can adjust to grab close to the floor. No joke i thought about mounting something to the floor to raise the height so it will grab closer to releasing.
Move your seat back a couple inches and the release point will feel totally different.
I have gotten so used the clutch friction point being high, my only problem is that sometimes when I get in to start the car I forget to push the clutch in far enough to disengage the interlock so the car knows the clutch is in.
Other than that, I just adjusted the seat so everything feels right when driving.
The 2014 clutch seemed less user friendly than the 2017 that I now have. The 2017 seems more like I envisioned coming from a 2006 C6. Maybe it was just that particular clutch in the 2014, it took 2,000 miles to stop grabbing. The 2017 clutch was smooth from the start.
In my 2016, it was the high and quick grab point coupled with the gas pedal's first inch and a half not doing anything. I was very concerned with too much gas at the bite point.
Yeah, late and grabby. 11k miles, and I still don't like it. Seems to be a little less grabby now, though.
I had the same challenge when I bought my C7. My last several cars had clutches that connected much closer to the floor.
I still prefer it that way but I got used the vette after a few months.
The high clutch release and feathering of gas is the single (and only) real complaint I have with this car (2017 GS). It is the only car that I have driven that I have to ride out the clutch. If the music is loud and I can't hear/feel the engine drivetrain engage I have often stalled it out.
Single, BUT HUGE COMPLAINT RE THIS.\
oh, and the dicked seat heaters
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
It has twin clutch plates which helps produce the lower required force. Takes a little time, but easy to get used to.
Nope it's not like a 1960's Corvette with those skinny tires! Thank goodness, recall when I drove my friends 435 hp 427 (note, that '67 was gross not the current net hp)- it changed lanes when I shifted near redline out of 1st and 2nd!
Yes, it's a far superior system to the antiquated stuff some are so fondly remembering with an engagement point close to the floor. It's also much easier to drive smoothly with a little experience.
Given the age demographic here, of which I am part, there's a lot of nostalgia about the old stuff, but that stuff was flat out inferior.
I am 41. I never drove the old stuff with a manual. The clutch feel is nothing like other high HP cars I have had. You get used to it but coming in, its weird.
