Starting conversion and build
So I decided it was time to do some needed body conversions. It is also time to probably start a thread and hope you join along with the mess I am getting into. Some of the photos have been posted but here is what I am doing.
Stingre' (03-24-2021)
jkippin (04-14-2017)
very pleased with the way these fit the body. I could actually have just left them as a bolt on but.... they are coming back off to be glued on. Next cutting the paint back and the gel coat on the and glassing in the seams for a one piece look. Not quite sure on how all the paint will look when finished my buddy is painting it for me and has some ideas with Candies, Pearls, Flakes, and Lace..... I told him I would be happy just to have the car so it looks good in one color but if he wanted to have fun go ahead. The side stripe is now gone too.
My hope is to show the direction I am going with this car as a true 70's style hotrod and not start any squabbles
Squabbles from an opinion generating thread like this on the corvette forum?!
I was lucky to be along for some r&d on this conversion one thing i cant stop saying is i love that the rear stays true to the heart and soul and importantly fatory look of the ducktail and its classic shape, this type conversion has long been sought after.
A cool part is the option to glass in or a if builder desires it can be left simple bolted on..sweet.
I also will follow along as you do the glassing in and paint work, people will likely want you to build your car their way and give opinions not to do the old school paint tricks,
i will be one to go the other way to say if it suits you i hope you allow your buddy to do some old school magic,
I am guessing you will get some lectures on not to glass the parts in how it will crack or show a ghost, i am sorry some guys cant get it to work out for them but the simple fact of that is if done correctly it will not have any problems and doing it correcly isnt rocket science.
I love the fit and look and you will have a car that is going to generate a lot of conversations so get ready and hold on for the ride,
Nam Labrat
Received 4,153 Likes
You've probably seen PRIYA's Conversion Thread?
Received 2,660 Likes
It appears that all the heavy metal bumpers have to be removed for this conversion....is that correct?
Installing these on my car was pretty straight forward. My car spent most of its life garaged and only has 80k original miles on it. The hardware all came out with ease.
Starting in the rear first I removed the vertical nuts that hold the bumper cover to the body and then the horizontal screws that held the cover along the top of the body.
Next I loosened up the bolts that are used for the bumper absorbers. There are 4 bolts on each side. I actually removed all the bolts then slid two uppers back in to keep from sliding out and hitting me in the head.
The Tail light sockets simply twist to remove and the license plate wire just unplugs.
I wanted to keep with the '68 theme so I used 4 red tail lights. I was looking around for the metal cups to install the lenses into but found out most they must be made of gold due to the high prices I found...even for junk missing the studs. So I opted to go with LED lights and used the gaskets to seal them against the body. I used Stainless Steel hardware and once I had them installed where I wanted them I epoxied the nuts in place. The same for the license plate bezel and the '73 license plate light.
Now its time to mount the panel to the car. No holes are drilled to mount it but it was very easy to do. I used manila folders made an outline of the rear quarters and traced the body outline. I cutout along the outline and now taped that to the body. The mounting holes can now be marked from inside the rear quarter panel. Go back tape this to the new panel and now you have the hole location. I waited for my Daughter to come over did a trial fit and then went from under the car and marked the top holes. I was able to used the stock bumper mounting strips along the top and sides.
I don't use a spare carrier so if you decide to do this you may want to remove it. Another neat thing is the LED lights plug right into the stock harness I bought adapter harness' to plug into the 1156 backup lights and used Weather pack connections. No butt splices or half a$$ed looking wiring.
To answer a few comments and questions...Yes the stock impact bars are removed. Yes you can probably fab something up and I probably
will.
more to come I welcome all positive comments.
will.
One other thing is you will need add two braces for the panel. GM used these that attached behind the license plate area and up to the frame.
I am curious about the front and how the center license plate area is dealt with....or is it all wide open? Kind cool looking wide open, but would need some type grille work.??
A center section is provided so you can make your own grill slats or keep the center open.
I will probably fab a complete custom grill from s/s bar stock and mount the directional lights behind it so to keep the front totally clean looking.
I am fortunate that I have a USA-1 plate on the front and only a rear plate and haven't had problems....Thanks I may have jinxed myself now.
