Buying new brake pad sensors for Z07 Carbon Ceramics
anyone know how to get these? I wanted to change my pads to Pagid since I track my car quite a bit, and they don't come with the sensors. The only way the local dealer sells them is with the pads.
the rear are fine and I transferred the sensors. The front are worn down and the sensors triggered, so now I need to replace them...
Received 8,927 Likes
Sometimes the sensors fall apart when you try to remove them the pad or the spring clips that hold them in place get loose and let them flop around. I haven't found any sensors separately available for the pads on the C7. However, I have found them for the C6 ZR1 (do a google search). They are shorter than the C7 versions but you can splice them into the C7 wires coming from the connector on the cradle.
Bill
Bill
I just spliced the wires together to eliminate the light on the dash. If you track the car as I do you should be in the habit of looking at the pads vs relying on the light anyway.
Additionally, I once had the sensors melt on the track and it left the light on, drove me crazy. Get rid of them till you go back to driving strictly on the street, less problems.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
RICH
