BluePrint 383 just mounted, fresh install and first problem
[SOLVED] BluePrint 383 just mounted, fresh install and first problem
Hi,
I just finish to mount the blueprint 383 crate engine 430HP full roller... But even if the motor start correctly and run "great".
I have a really strange noise. Any advice, what you thinking about it?
Thanks
Thanks
Received 3,043 Likes
St. Jude Donor '05
Uh oh not good..(sounds like valvetrain)first off call blueprint...(are all these motors run before shipping curious)
How is the oil pressure?
If good, remove the valvecovers one at a time restart see if its still there
sometimes the rockers can touch the inside of the valve cover depending
Hard to be sure from a video, but it doesn't sound serious to me. I'd be looking for something rubbing somewhere. Fan blade on the shroud, flywheel on the bellhousing shield, etc. Take your stethoscope and see if you can figure out where its coming from.
St. Jude Donor '05
good call on the pan
Dr. Detroit
Received 3,891 Likes
Sounds like flexplate rubbing.....is this an auto trans car?
Jebby
Jebby
I had a rocker hitting the valve cover on a new ZZ383, didn't sound like that. Pull the valve covers and check for wear then move on to other areas that have been suggested.
It's not the FAN because it is electric and with or without him, i have the noise...
Any Shiney spots inside the valve covers? Doesn't take much.
Solved !
No metal filling in the oil filterand in the oil. No shiney spot.
We solve the problem using a drill with the correct tip to start the oil pump (during 10-15 minutes). After oil perspire by rocker. We start again the engine. No more noise Just after use a stromboscopic light to make my advance right (8°, BluePrint recommande 32-34° @ 3500trs. How many @750trs?).
My Corvette will be ready soon to take the road
Thanks for your assistance.
