How to force the Heat Exchanger pump to turn on?
https://www.corvetteforum.com/forums...mp-switch.html
While you're at it you might want to order some memory enhancing pills since you were a contributor to this thread
I was wondering what HX pump you were talking about, but it looks like others have figured out it must be the CAC pump you're talking about.
As noted in the earlier post, there's a forum member's solution.
Or, forum vendor GSpeed has this switch that can easily be installed/removed when working on the intercooler coolant system:
https://gspeed.com/product/z06-inter...-override-tool
GSpeed (05-04-2017)
lol. I seen that thread. I don't quite understand his wiring setup. I just need to turn it on to bleed the system. I don't want to order the switch because I'm trying to finish today and getting the car tuned so they will run the pump full time. Just trying to figure out how to jump that fuse to keep the pump running long enough for me to get the air out.
I have bled my system by just turning the key on, I am currently configuring a switch so I can run the pump without turning the key on.
Leeds.io
St. Jude Donor '14-'15-'16
Im sorry for being slow but exactly what needs to be done to do this?
ive emailed GSpeed about a switch as they're currently backordered. Can I borrow someone else's switch? PM me.
I want to attempt to get my bubbles out.
Best,
Gene
phantasms (05-18-2017)
Leeds.io
2. I don't have a friend who has this but maybe I can be that friend and help myself out. Then again I have tremendous fear for what would happen if HPtuner, myself, and my 40k miles Z06 get together.
Best,
Gene
Per another thread on the same subject, someone who tried this said it only turned it on for a short time, something like 30 seconds.
1. This doesn't flash anything right? No warranty nonsense? I'm 99% sure it's a no but want to be sure.
Best,
Gene
Best,
Gene
One thing I forgot to mention is you would need a laptop to open the HPT scanner to use the controls.
Supporting Vendor
Were back in stock, sorry for the delay!
Believe it or not, I dont recall HP tuners being able to turn the pump on. Because its on its own circuit, its not like the Zr1 where you can command the pump to turn on. Someone please fact check this. Ill plug into a car here just to verify.
If your pump is turning on for 30 seconds, it probably has air in it and shutting down.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
Leeds.io
Dude. Thank you very much for the offer! Once I saw the post below I figured best to support the vendor but thank you.
Ordered!
p.s. you're website still says it's on backorder.
Now hopefully I can get more out of this thing than I put into it while messing the whole process up.
Best,
Gene
Ordered!
Best,
Gene
GSpeed (05-18-2017)
I have an Autel scanner I use at my business, it will turn the pump off and on, it does however have a timeout feature. I have not timed it yet, but I am thinking it will run it 2-3 minutes. I will check and verify it this weekend.
tracer3030 (05-19-2017)
Received 2,379 Likes
GSpeed (05-19-2017)
