170F thermostat
160 F didn't work in my car without a tune due to weird electrical things happening like AC quit, radiator fan kept running and engine temp gauge went to 100F. Also I found the gasket loose on my 160F Mishimotor when I was removing it.
I now have a 170F without a tune which has been working fine for 1K miles. Bought it from Katech but it is actually a Summitt SUM-366-170.
What temp range does your car stay in with this stat when daily driving/cruising? and the outdoor temps to go along with this range.
Somebody has to be running the LME 160 without a tune.
Had no idea the gasket was coming out. The weather had been cooler and engine temps were being maintined around 160-165F with no issues. I have been told at 160F the lower temperature violates a permissive in the stock tune.....engine too cold for too long.
A 170 is fine by me. Thanks for the part number. Does the build quality at the seal look better than the 160 that failed ?
With 60F outside air and car moving down highway the engine temp ranges in the 170-175F. Once air temps start going up so do the engine temps. With 80F outside air and car moving down highway the engine temp ranges in the 175-180F. So far the highest I've seen engine temps were 190F in stop and go traffic with air temps around 85F....of course I was using the AC which I believe keeps radiator fan on.
I'm not sure of the temp but if the car stays under that temp for to long it with set a code. I think the temp is below 160 but not sure and my 170 lingerfelter stat would heat up quick like the stock stat and cruise around 180-182 most of the time in 7X temps.
Without a tune, you will have problems with a 160 thermostat. CEL, erratic fan operation, etc. this is the info I found through research on here.
The lowest you can go without a tune is 174.
I got the 174 lingenfelter LS3 thermostat and the LMR therm housing. So far so good.
We still need a way to engage the oem engine cooling fans at lower temps without a tune, as far as I know no one has figured this out yet.
It it would also be nice to be able to operate the elect water pump as well as the rad. Fan manually while the car is off, to expedite cooling between drag runs.
If the DashLogic guys can display knock count on the center stack, they seem to be pretty far into the electronics. Someone should see if they can figure it out!
I'd buy a module that gave me water pump and intercooler pump control and that lowered my fan set points, for example.
