C6 ZR1 Spoiler part #
So, I'm looking to put a ZR1 spoiler on my 08 base. I've read a lot of posts about the ZR1 spoiler and it seems almost unanomous that the only ones that don't have mixed reviews are the GM OEM genuine ZR1 spoilers.
The problem is I've seen two part numbers and don't know the difference between them. Can someone help?
19256906 vs. 19180369
Thanks!!
Thanks!!
The only difference that I can see that would justify the price difference is one being carbon fiber and the other abs plastic. Then again, $608 for a carbon fiber spoiler from GM seems cheap too.
Same part. The 19180369 number appears to be replaced by 19256906.
They're paint to match at any rate now, they used to be available body colored years ago.
https://www.gmpartsgiant.com/parts/g...-19180369.html
http://www.wholesalegmpartsonline.co...wd=&origin=pla
Received 3,066 Likes
The spoiler comes without the center brake light assembly. You will need to remove the light from your original spoiler and re-install it into the ZR1 spoiler (easy).
I may be wrong, but I think the OEM ZR1 spoiler does not come with the installation nuts. You may have to buy them separately.
BTW ... You are going to need to drill some holes in the top of your rear fascia (bumper) in order to install the new ZR1 spoiler.
Nate_M (04-27-2017)
As for the drilling, I've watched the videos and it seems pretty straight forward. Obviously I'm nervious, but from all the reading I've done this is the best option if you want it done right the first time.
You can try part number 11508388 and that may be replaced by 25601643. Search around and they're around 3-4 dollars online. Local GM dealer or Rock Auto even has them. (Amazon is crazy money it seems when I looked.)
Nate_M (04-27-2017)
Turbo is correct, you can re-use your brake light & the nuts need to be ordered separately.
Good to know Curt. I've seen mixed reviews on the RPI. Seems like some have no problems yet others I've seen recently have dimpling, etc.
Do you have any additional picture of the car with the spoiler installed? You have a Crystal Red just like mine and I'm really anxious to see how it would look before I pull the trigger.
Oh, and in regards to RPI....my experience with them was less than bad. Choose wisely.
Nate_M (04-27-2017)
The car is dirty. It has been sitting in the garage since Saturday night.
For the top view I was holding an LED light so you could get an idea of the color. Now...being VERY picky...the paint lacks a little depth that the stock paint has. It is not noticeable unless you are out of your mind like me
Nate_M (04-27-2017)
My guess is the dimples are on the cheap ones or ppl are tightening the spoiler too much. I literally tightened the nuts just holding a deepwell socket in my hand.
Just watch when you're tightening them down. Observe the rear fascia and see that it's not sucking it down too much . On a couple of the spoiler studs, I seem to remember there are sometimes shims/washers so that it will sit flush. You'll know what I mean if you look from the side to see if it's wavy after tightening.
And yes, I've seen some good, some...needs improvement, stories with a few of the aftermarket ZR1 spoiler vendors. The only one which doesn't have negative reviews are the OEM ones who color match locally. I know I'm paying double the price, but I'm not about to drop $400 on something I reget when I could have something I LOVE for less than a grand. I don't get to enjoy the car as much as I want, so when I'm in it I only want to be focused on having a good time, not being distracted by my neurotic obsession for perfection on my less than satisfactory spoiler. For the extra $, it's just not worth the risk. I know not everybody has the luxury, or crazyness, so I get why they go the route they do. I've simply learned how to make due without unless I can do it the way I want it done haha.
Former Vendor
It always amazes me how the GM / ZR1 non-painted spoiler cost about $720 .... But the GM / Full Width (aka: Ron Fellows) painted rear spoiler can be purchased for about $320
http://www.trunkmonkeyparts.com/oe-gm/20921726
Confused !
Confused !
subchev (04-27-2017)
Confused !
Confused !
