check engine on and fans running
Ideas ain't going to fix it! Might lighten the wallet but I'd say you either have it checked or learn the "how to"!
How long have you owned the car? Any recent attempts at some repairs or maintenance that you've attempted yourself? If you've recently done anything - go back to what you've done and sort from there.
If you've done nothing -
http://tech.corvettecentral.com/2011...trouble-codes/
With a '90 and if it has C68/ATC you could use the AC Control to maybe check the coolant temp that the ECM sees and use that as maybe a "clue/hint". If no C68 rely on the diagnostics.
I imagine you don't have a FSM (Factory Service Manual) and if the car is a keeper I'd suggest you buy one. Print or "electronic media" are both available - some have and use both, some have preferences, some might have made a different choice after buying one or the other.
I have both but use "digital media" more frequently.
Cruising
1C1 section of the FSM
