82 corvette ignition lock cylinder replacement on a tilt telescope
Follow the link above but on some GM vehicles the hole where the tab pops through To hold the lock cylinder in is covered by a thin layer of aluminum. When they cast the columns the casting is usually chipped away but if it's not, you have to guesstimate and pick at it with a small chisel until you can press that tab in.
