Technology, Good or Bad?
2016 C1 of Year Finalist
The thread about "breaker-less ignition" is interesting but there is no general answer of which is better, points or electronic ignition, IMHO.
I think it is totally dependent on the application and use of the car. I have had a original Pertronix in my 62 for 20+ years with no problems.
I have used, played, screwed up both original Rochester fuel injection and EFI. Which is "better" is also without a answer IMHO.
I have had a first design 4360 unit on my 57 (sold) which performed flawlessly for many years under all conditions, hot, cold, etc. It was tuned by a professional and that was the key to good operation.
I now have a old Hilborn 8 stack mechanical injection which I converted to EFI using a FAST EZEFI 2.0 controller. It also runs very well and is actually pretty user friendly and even I can adjust and mess around with it.
So which technology is better? I like them both.
Any comments?
Bruce B
Any comments?
Bruce B
Received 6,939 Likes
2015 C2 of Year Finalist
Technology is only good as the person who is using it. At the end of the day if it gets the job done how the user wants it done. Then that is all it matters. My one dumb Holley carb, points, and repro wires makes my car run great and can smoke the tires at will
ohiovet (04-28-2017)
I hate percolation; equally hate vapor lock. They are mysterious issues. My clone carbs on my 270hp '61 never once suffered from heat soak, percolation or vapor lock.... I personally rebuilt those, sold 'em after 20,000 trouble free miles and another forum member has run them, untouched, for another 30,000 miles.
My lil ole mouse motor 63 also with a WCFB suffered from heat soak, which I solved...now on the hottest days in Orlando it'll vapor lock while underway and cause an embarrassing excursion to the side of the road to cool down for 1/2 hour. Yes, I rebuilt that carb too.
I freakin' don't get it.....it has me considering an F/I conversion just to make the car driveable... So, in short, I'm on the fence about induction technologies..
I start to get vapor lock if I sit at traffic for longer periods of time start to back fore and run like crap and If I shut my car off and let it sit for a couple of minutes and turn it back on it will star to act up. I thought of putting a spiral fan inside the shroud and hide a remote switch underneath dash. Help cool everything down
One old timer told me to put tin foil around the fuel pump line to carburetor.....I'm not sure how that will help??
EFI is superior in every way except simplicity. Fuel economy, emission control, driveability, reliability, maintenance, and performance. Even engine longevity is improved (more complete combustion, less unburned fuel and byproducts sneaking past piston rings). No carburetor ever built can match a properly-functioning EFI system in any way.
I was very slow to come around to this opinion, thinking for years that the relative simplicity of carburetion won out over the advantages of EFI, but I can no longer accept that argument. It just can't match up.
Live well,
SJW
Live well,
SJW
Received 1,843 Likes
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
https://www.corvetteforum.com/forums...fuel-pump.html
St. Jude Donor '07
Any comments?
Bruce B
Any comments?
Bruce B
I used to use a CD ignition with regular points and it worked flawlessly too, but that is gone with the EFI...
where one can get it trouble with new technology is when it is 'old' and no longer supported. I am now the possessor of 3 'orphans', an Accel EFI, a HotRodAir a/c, and a Keisler SS700...
Bill
Live well,
SJW
Live well,
SJW
Any comments?
Bruce B
Any comments?
Bruce B
Ok that's a new why clothes pins ?? Keep the gas line away from the engine??
Yeah I am almost at the tender age of 49. I remember those used back in the good olds days lol Grandma and Mom used those ancient artifacts back in the day...
St. Jude Donor '07
surprisingly, the intent of the clothes pins was not to keep the gas line away from the engine; I think it was some 'voodoo' magic, or just an additional heat sink...
whatever the purpose or the results, there were 'true believers'...
Bill
Bill
The clothes pins do the same thing as the fins on a radiator which are part of the tubes that the coolant runs through and disapates the heat away from the tube or in this case the fuel line. It will work if you can get enough of then on the fuel line to make a difference.
Clothes pins are a total urban legend. Wood is an excellent non-conductor of heat. That's why its used for carb heat spacers. The pins are nothing like the metal fins of a radiator or the heat sink on a power transistor.
The clothes pins have about as much effect as slaughtering a goat and spreading the entrails across the motor.
The following 3 users liked this post by Frankie the Fink:
