Purchased the C7 Nav update - Warning!
St. Jude Donor '11
Against the advice from this forum, I purchased the Nav update for my '16. I know... Likely a waste of money, but I'm kind of nerdy about stuff like this..
Anyway, arrived in the mail. Read the instructions...
It takes at least 50 minutes to update from the USB stick. The kicker is that the car MUST BE RUNNING. Not accessory... Motor RUNNING.
I was looking forward to updating in my garage. Now I have to plan an hour long trip, somewhere. Oh, and you can't stop and restart. Must keep engine running for the entire download. I could do it in the drive-way, but not liking the car sitting in hot AZ sun, idling for an hour.
Here is the funny part. To see if it worked, you ask to find a Starbucks, in Detroit, that wasn't there a few years ago. I wonder how much Starbucks paid for that little commercial??
ZenicaPA (04-30-2017)
I believe that you can put your car into "On" mode (not accessory) by pressing and holding the start button and not depressing the brake pedal (automatic) or clutch pedal (manual). Just push and hold the srart button until everything lights up (takes around 10 seconds) and you should be good to go. I know with 100% certainty that the C6 has this capability and I'm quite sure the C7 does as well.
WMark (04-29-2017)
Yes, this mode is also called "service" or "service only" mode. Hold the start button w/o foot on brake or clutch in for the vague 5-10 seconds.
Although, I think I would have the car hooked up to an external power source, if an hour is needed. Just to be on the safe side.
It's a useful mode. It's much like keyed ignitions "on" position, you can do pretty much everything there as when the engine is on, even running codes. Helpful, especially if the car won't start.
itaylorm (04-29-2017)
St. Jude Donor '11
I believe that you can put your car in "On" mode [not accessory) by pressing and holding the start button and not depressing the brake pedal (automatic) or clutch pedal (manual). Just push and hold the srart button until evert hinges lights up (tales around 10 seconds) and you should be good to go. I know with 100% certainty that the C6 has this capability and I'm quite sure the C7 does as well.
To quote the instructions, "Important: DO NOT remove the USB device or TURN OFF the engine until the update is completed. THE ENGING MUST BE RUNNING THE ENTIRE INSTALLATION PERIOD."
Last edited by Steve Garrett; 04-29-2017 at 06:18 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your responses look like this!
The service mode is just as if the engine is running.
Or you could just drive an hour somewhere. That's better for the car than just sitting idling in the driveway, at any rate.
eta: my guess is that they don't bring up the service mode because they would have to explain what it is, and 90% of Corvette owners never have heard of it, and then they would have to tell you to plug your car in or you risk running your battery down. Too complicated for them, so they just say drive it somewhere. Doesn't mean it won't work.
The following 2 users liked this post by owc6:
Rebel Yell (04-29-2017),
WMark (04-29-2017)
WMark (04-29-2017)
It does NOT time out.
You must exit service mode. Thanks for bringing this up.
WMark (04-29-2017)
St. Jude Donor '11
Love this forum. Still great after almost two decades! Thanks to owc6 and mpuzach for helping out!
Will follow their recommendations, and report. Thanks, people!
If you go for an hour ride, make sure you don't stall the engine (If you have manual trans)
The OEMs are just way behind the technology curve. And they are greedy and want to extract as much $ as possible for their crapulant nav systems that are inferior.
I once updated my Acura where the maps on a brand new car were four years behind and was constantly driving off road as the highway outside my house was only sitting there for 4 years. Took them two years to come up with a map update!?!?! I was so pissed at it complaining it was off road and "recalculating" constantly I was ready to sell the POS.
At least with the Acura you could shut off the car and the update would continue on restart. But it took SEVERAL hours! I finally left the car with the engine on but not running in the garage hooked up to the largest battery charger I had. A trickle charge won't cut it.
CF Senior Member
More importantly, once you get the update done (by whatever means) let us know if you think it was worth the cost. Most Nav updates are already way out-of-date by the time you get them.
I got into service mode and didn't know it. I was resetting the oil percentage and then could not restart the engine. The dashboard would light up and then go out when starter button released. Called On-star and was turned over to a person who tried to guide me thru. Nothing was mentioned about service mod. After following through his directions, he said he would get a tow truck over. I waited for about 15 to 20 minutes tried again and it started. Called up On-star and had tow truck cancelled. Took it to the dealer next day and was brought to the service bay and told the problem to the Corvette technician. He checked the complete electronic system. No problems. He said most likley it went into a "diagnostic" mode. He said if it happens again, get out of the car shut the door, then get back in, foot on the brake then press starter button. It has not happened again so I have not tried his direction. This Corvette tech is one of the most highly qualified Corvette technician in the country.
