Z06 'play' in the rear.
I am not sure if it is normal for a z06 or any manual car (my first manual is the z i currently own) When I let off the gas and then get back on it I feel a little bit of play. Like the diff has to catch up or something. Kinda like a split second delay between when I hit the gas and the wheels actually start to do something. Makes a little noise when it happens. Could it be rear suspension? I am hoping this is just normal..
mpetty (04-30-2017)
I have a 02 coupe, and it has some play in it also, when I punch the gas from stand still, I haven't heard a sound from it when it does that, I just let off the gas when it gets a little fishy. I would say maybe it's normal? This is the fastest car I have owned ever! Loves it to pieces.
Banned Scam/Spammer
Received 1,319 Likes
Inner and outer tie rod ends keep the rear wheels straight/aligned.
They should be changed well before 100k miles. I've seen the worn out on 60k mile cars. When you get on the gas the rear wheels cause the rear to get fishy (not talking about wheel spin). This can be very dangerous especially at higher speeds and you slam the next gear at redline and the tie rods flex and the rear squirms. Say hello to GOD.
Banned Scam/Spammer
31k miles should be okay. Just in the future as the miles increase when the rear wheel(s) is in the air in front of you, grab the wheel at the 9 & 3 o'clock position and aggressively rock back and forth. If you feel any play at all it's a dangerous situation. 350+ ft lbs of torque makes that wiggle much more pronounced.
Next time you play around with launching your cars, hit the traction control button and see if what you're describing goes away. Traction control prevents you from learning to slip angle in corners, which effectively kills your ability to control the car at any speed in tight areas anyway. You will never feel confident if you drive with TC on at all times, because the car will do strange, unpredictable things around your traction limits.
I learned to drive in a miata, so it took me a few months to settle into my corvette and feel comfortable driving with traction control off at all times. It's surprising how much faster and more agile the car feels without the nannies constantly robbing power. It sounds like its time for you to take off your training wheels... most of the time, keep them on in the rain!
mpetty (05-02-2017)
I simply said those tie rods get worn and make the tail end wiggle mainly when a dose of torque is applied. Not a good thing when the speed is high.
Are you guys playing with launching your cars with traction control on? If you spin your rear wheels, TC guts the power to your tires. It feels a little weird and unstable with power shifting between tires and locking up a little... and what you two are describing kind of sounds like it's on.
I am not launching it. But the tie rods sounds like something i should get checked out when i go in for the valvespring swap at the dealer. Also i hit a pothole the other day and my ABS and tcs went out!!!! i get the service tcs service active handling service abs everytime i start it
