[Z06] Start up problem
St. Jude Donor '12
Start up problem
Car (2002 Z06) has been running great but recently developed an issue were when i put the key in the ignition and go to turn it to turn the car on nothing happens. The car does not crank at all. The battery is full, and all electronics work fine. i also tried using the other key but same result nothing happens. After turning it over a couple times over and over it finally will turn on and the car runs fine and will turn on fine after that. then a Couple days later it will happen again. Has anybody had this issue and possibly know what it is?
Sounds like a startup problem to me.
