57 fuel injection no gas
i put my 57 on the rack to adjust the shifter was running fine adjusted shifter went to start it won't start. got fuel pressure right to the fi 6.5 lbs tons of spark . plugs are bone dry not getting gas anyone have any ideas i no nothing about these Rochester systems. zano
Received 1,843 Likes
Do you know anything about punctuation or capitalization?
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
jerry gollnick (05-22-2017)
But I didn't complain about it.
Common courtesy anywhere to use something close to correct spelling and/or punctuation so you can read a post. I found this one difficult to read and said so. Your post is uncalled for and unproductive.
He can crack a line going to one of the nozzles and see if the line bleeds pressure while the engine is cranked. Another thing, shoot some aerosol brake cleaner in the air intake and see if that makes it run.
If you would like to educate yourself, click here:
http://chevy.oldcarmanualproject.com...ction/fi01.htm
Or here:
http://www.oldcarmanualproject.com/m...0Injection.pdf
I barely made it through the eighth grade but I can do a little better than some I see here that post without punctuation and capitalization, run sentences together, etc.
This results in confusing, unclear questions that are hard to make sense of without further questions.
Get an aspirin and chill out.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
The following 2 users liked this post by DZAUTO:
427390HP (05-21-2017),
Bill Pilon (05-22-2017)
Or even be able to try and understand what is being asked without having to re-read the run on sentences 4 times over. What's so hard about hitting a period or comma key?????
The cable housing is located on the passenger side between the distributor and rear of the fuel meter. If the cable is not broken, check the cable ends, they should be square. Measure the cable length, this changed depending on year and model of injector, from memory somewhere around 6 1/4 - 6 3/8. Post your distributor model and injector model and others will chime in on what the correct length should be. If cable is good crank the engine to see if the distributor cable drive shaft is rotating. Post back with what you find. I hope I got the speeling and puncsinnation correct..
vmaxpwc (05-22-2017)
Some are funny about those not filling out a profile since you asked.
I am guessing that we are all grown men on this site and long past school. The point is you can't educate people that have a problem with the written language on this forum. Just try and figure out what they are saying and try to help without the peanut gallery, condescending remarks of don't respond I all I am saying.
If you don't like a thread for what ever the reason you have the power in your fingers to not click on it.
