ABS TCM Light
ABS TCM Light
Recently I replaced the brakes and rotors on my 2002. Now the abs and tcm lights came on. I have a c2181 code. Anyone familiar with the disease and the cure and is this something a seriously amateur mechanic should tackle.
Thanks in advance for any and all replies
abs/tcm lights
I would start by clearing the code and see if it returns. C1218 is a relay issue operating the BPMV and the relay is inside the EBCM. Might also be caused by bad grounds. Worth checking grounds before going further with potentially expensive repairs. Here are a couple links relative to grounds that may help:
http://forums.corvetteforum.com/c5-t...locations.html
http://forums.corvetteforum.com/c5-t...tion-long.html Post #1
and one with some pics
https://www.corvetteforum.com/forums...re-report.html
abs/tcm lights
abs/tcm lights
Sounds to me like you somehow disturbed some electrical connections/grounds near where the catch can was installed. There is a ground point on the passenger side of the car near to where the catch can would normally be installed. Time to take some careful note of electricals around where you were working..............
