1982 sending unit
Old 05-22-2017, 02:45 PM
mkz5951@gmail.com
mkz5951@gmail.com's Avatar
Default 1982 sending unit
Do you have to drop the tank to change out unit?I was told you can get it from
the top.
Old 05-22-2017, 03:09 PM
MelWff
MelWff's Avatar
Received 1,806 Likes on 1,597 Posts
according to this thread it can come out the top surprisingly
https://www.corvetteforum.com/forums...nit-wires.html
Old 05-22-2017, 04:41 PM
hugh9222
hugh9222's Avatar
YES Here is the link to my description on how to do it. Message me if you have any questions. Hugh
https://www.corvetteforum.com/forums...post1589065537
twofast (08-08-2017)
Old 05-22-2017, 07:22 PM
Jeffs82c3
Jeffs82c3's Avatar
It comes out pretty easy, if you replace the gasket, it can only go on one way, the bolts around the filler are not the same spacing.... Good luck...
Old 08-08-2017, 09:01 PM
twofast
twofast's Avatar
I've removed mine 3 times. The first time I did it I fiddled and twisted for what seemed like hours before I finally got t out. The second time I followed hugh9222's directions exactly and it was a breeze. Thanks Hugh.
Old 08-08-2017, 09:23 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Yep, through the top and it is pretty easy and straight forward actually. I have only seen one 82 that I could not go through the top and that was due to someone removing the tank previously and when installed was not lined up the way it should be and was off enough that you could not get the pump assembly out of the hole no matter what. Other than that, it should come out easily.
To 1982 sending unit
Quick Reply: 1982 sending unit
