Will a 67 repro teak steering wheel fit on a 66?
2015 C2 of Year Finalist
A wheel made using a 1967 spoke assembly will not fit on a 1966 column without modification. The 67 bell was changed with a cast relief to accommodate the "stepped" spoke design of the 1967 wheel where the lower spoke overlaps the center and two horizontal spokes.
vwtdi (05-23-2017)
Received 6,944 Likes
unless it was custom made there is no such thing as a 67 teak wheel. and as said about 67+ wheels have a step in the bottom spoke and thus the hub has a relief made to mate the step. 63-66 hubs and wheels are flat
vwtdi (05-23-2017)
I think all you need is the "C" shaped spacer on this Ididit adapter.http://www.ecklerscorvette.com/corve...1963-1968.html
no that wont work. that is a replacement for the stock hub.
That's not a spacer. That acts like a factory hub on the aftermarket column. If you want to run a 67+ wheel on your 67 your going to have to mill out your factory hub.
Just get an after market wheel like a Grant #930. Looks like stock and bolts right up, no mods.
It fits 63 to 66 hubs perfectly, has a spacer to fill in the slot on the 67 hub.
St. Jude Donor '05, '09, '15
The crude drawing of the spacer alone in post #10 is mine. I made and used this spacer before I got the the one on the Ididit hub. It also works.
Strange coincidence but just today I contacted Ididit and asked if I could purchase a spacer by itself, no hub. They said yes. I ordered a couple in "raw' finish. Not sure what I will get but they are on the way.
Tom
