C6Z calipers on C5, which brake lines?
Received 1,261 Likes
I had some stainless lines from kore3 and wasn't really impressed with them and swapped them out not long ago for Doug Rippie's lines... they are made by goodridge and use -an fittings instead of banjo bolts... they are a little more expensive than other stainless lines but I really like them and they were worth it to me... http://dougrippie.com/featured/drm-s...l-brake-lines/
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I thought I was prepared by having the StopTech stainless versions on hand when the swap took place (for a C6z), and was in for a shock when they were wrong....
Luckily, I have a local builder (D.O.T. approved) that whipped me up a set of s/s hoses to fit in a couple of hours.
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
DRM lines here. I prefer the steel AN fittings over the banjo bolts and crush washers.
