Tire pressure sensor recalibration
Popular Reply
05-24-2017, 01:00 PM
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
1. start car - actual engine running - not the Acc mode
2. Select the tire pressure display in the DIC.
3. Press and hold the SEL button until the display changes and the horn beeps. It now says it's in learn mode.
4. Now drive just as it says in the manual - 10 min or so above 12 mph.
5. Suddenly, it will find all 4 sensors and show pressure
6. when you shut the car off , the "learn DIC" will show again and horn beeps.
Elmer
Elmer
E-Ray, 3LZ, ZER, LIFT
Received 9,603 Likes
Hmm, did not think it was possible to "calibrate."
And if it was- what would you calibrate it with?
Or perhaps like in favorite move, "My Cousin Vinny," and Mirisa Tomie's statement, that the gauge used was calibrated a split second before use by the State and Federal Bureau of Weights and Measures and is "Dead-On ***** Accurate." An industry term, according to her!
There was a thread on this not too long ago. The consensus was they could not be calibrated. I think one guy said he was successful at doing so but he didn't respond to "how".
What makes you think they need to be recalibrated? I had one sensor fail to give any reading at all on my C5 and was able to reset it by running a kitchen refrigerator magnet around the sensor while it was in the rim. True story. No such issues with my C6 (ten years) or my new C7 (2 mo.).
Elmer
Elmer
The following 17 users liked this post by eboggs_jkvl:
BRussell (05-24-2017),
dbell66253 (05-18-2020),
GeoGS (06-21-2021),
Hemi Dave (09-16-2017),
jimmie jam (05-21-2021),
and 12 others liked this post.
The above is done when you rotate tires. It teaches the tire position. Does not calibrate the TPMS
72rdstr (10-03-2022)
Common practice in industry to have gauges calibrated and certified annually against a known standard. Not cheap and a good business.
I use a technique also employed when buying an aquarium thermometer. Look at all those on the shelf and pick one that is closest to the median. Sometimes have to not include a high or low! Not perfect but better than nothing.
For my tire pressure gauge, occasionally will measure a tire with the four I have. My $60 Jegs didgital is usually close to the average and within a pound of the Vette display readings-good enough! It reads to a tenth so makes me feel better! At least it is a good comparison.
For the Vette and Street Rod I use a large analog gauge that is connected to Teed hoses the balance two tires! For the Street Rods wide rear tires that is only 16 psi.
That process hasn't been necessary when I rotate my tires or change between my winter and summer tire sets. The car automatically recognizes whatever sensors are on the car with no action required.
bjones7131 (11-22-2017)
Received 8,917 Likes
The real question is do you mean recalibrate as to make sure the sensors are reading the air pressure accurately or do you mean reprogram them?
Tire pressure sensors are calibrated about as close as any tire pressure gauge is calibrated when they are built. Hand held gauges can be sent to a calibration lab to be calibrated to a known standard but that can't be done with the tire pressure sensors.
If you mean reprogram them that is a misnomer since the gauges aren't programmed the car is programmed to recognize each gauge and where it is located. On the C7 this is done automatically by driving the car.
Bill
Bill
OK, my choice of "recalibrate" was incorrect. I am replacing all tires and wheels next week. My previous four Corvettes had procedures for the RESET of the TMPS. But since I have found articles on the internet stating "not all C7 automatic reset works correctly". Therefore, I reached out to you guys for your experience, expertise and English lesson.
Elmer
Elmer
Elmer
The following 2 users liked this post by eboggs_jkvl:
72rdstr (10-03-2022),
John Micheal Henry (09-04-2017)
I can confirm that as well. Put new wheels with brand new TPMS's on my car today and it learned them pretty quickly.
whiteboy444 (06-03-2020)
Owner's Manual 10-56
TPMS Sensor Matching
Process — Auto Learn Function
Each TPMS sensor has a unique
identification code. The identification
code needs to be matched to a new
tire/wheel position after rotating the
tires or replacing one or more of the
TPMS sensors. When a tire is
installed, the vehicle must be
stationary for about 20 minutes
before the system recalculates. The
following relearn process takes up
to 10 minutes, driving at a minimum
speed of 19 km/h (12 mph).
A dash (-) or pressure value will
display in the DIC. See Driver
Information Center (DIC) on
page 5-23 and Tire Messages on
page 5-39. A warning message
displays in the DIC if a problem
occurs during the relearn process.
Elmer
Elmer
Well Elmer, regardless of what the manual says, all I can tell you is that I bought new wheels, new TPMS sensors, and new MPS AS3+ tires, had them mounted and balanced, brought them home, bolted them on myself, and did absolutely nothing to have them recognized instantly as soon as I started the car and before it moved. The pressures read exactly what I measured with a tire gauge on each corner.
When I put the OEM PSS set back on a couple of weeks ago, it read the correct pressures on those instantly as well.
The following 3 users liked this post by Foosh:
Received 9,512 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I had to use the learn mode process when I changed my Grand Sport wheels. The car did not recognize the new sensors until I followed the procedure outlined in the manual.
