96 Base Coupe - Finding Cruise Vacuum Hose
I needed to clean my battery terminals and in the process pulled the vacuum hoses off the cruise control unit to move them out of the way. After reconnecting, I realized the other end of the hose that goes to the brake pedal switch had pulled off. It's not in good shape and should be changed anyway, but with all the harnesses and pipes routed through there, I can't see where it connects - I assume somewhere under and behind the brake booster.
Before I start removing stuff to look for it, can you give me a hint where to look?
Thanks.
Thanks.
Those vacuum lines go to the back (toward the firewall) of a switch on the brake pedal. Its purpose is to disengage the cruise control when you step on the brakes.
Pass through grommet in this vicinity - follow the hose
five7kid (05-25-2017)
Would be nice is if was more specific, though.
I just didn't know where to look for the line to the switch in the engine compartment where it passes through the firewall so I can get the hose reconnected. It appears to go to the right of the power brake booster, but I can't see any hose nipple sticking out in that area without moving other stuff out of the way - I wanted to get an idea what area to look in so I can move stuff out of the way get a better look for it (a lot of stuff is packed in that general area).
Changing oil today so I looked in there on my 96 LT4. The hose kind of disappears under the brake booster just a little to the left on mine. But with the battery in there I just couldn't see all the way to the firewall. Looking down past the valve cover on the engine side of the booster, I could see pretty deep, but I couldn't see that hose at all. Sorry, no help here. Looks like the battery is going to have to be out of the way to see up under there. That particular hose on mine feels dry and brittle so I'll probably have to find that pass-through location soon too.
Such a little thing. But I like my cruise control...
Finally figured it out last night. I pulled out the PCM and the ASR in order to see better and to be able to get my arm through and hand in there. I finally found about a 1/4" piece of unconnected hose sticking through the firewall - I expected a vacuum nipple.
Turns out the hose is supposed to be one piece from the brake valve to the cruise unit. It apparently isn't the original hose. There was about a 12" section from the unit, with a splice/reducer there, and a degraded piece of hose going through the firewall to the brake valve. The hose hadn't disconnected like I thought, it BROKE! It was deteriorated so badly that the act of disconnecting the other end broke it off.
There was plenty of "good" hose left inside the car, extra, even, so I pushed about 3" through the firewall and cut off the deteriorated piece (only required removing about 1/4"). I just plugged the existing splice/reducer into it (well, I say "just", but couldn't get both hands in there, so had to hold the piece with the splicer with a long pair of needle-nose pliars - took several tries), routing it directly under the brake booster this time, rather than routing it close to the engine as was done before. Works great again.
At least I didn't have to pull the battery or booster...
I don't know how long the piece of hose (which looks like chain-store bulk hose) will last, but I'm guessing at least several years.
When I bought my 94, the seller said the cruise didn't work! But he had replaced the battery. Sure enough, when the new battery went in, the vacuum line came off and was squished under the battery. Wiggled it out and the cruise works. Love a cheap easy fix!
