[C2] Idler pulley purpose
I do not know the purpose or reason for the idler pulley that was original equipment on my original 340 HP engine. I still run an idler pulley on my current power so having the reason would be an interesting bit of information. I did find them on 409’s in the junk yard back in the day. Thanks in advance and safe driving to all.
Steve Stone (original owner ’63 triple black convertible, 550,000 miles)
Cruise-In III Veteran
Hi Steve,
I admire your use of your midyear! Someone once said it ain't the destination, it's the journey Kudoos to you and yours! To your question, I believe all the solid lifter small blocks had the idler pulley because of their higher revving capabilities. The pulley was deep grooved to aid in keeping the belts from spinning off at those higher r's. Others will chime in on this.
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
Steve Stone (05-24-2017)
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Hi Steve,
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
Jim, I agree with you, you got it right.
Dave
6T5RUSH (05-25-2017)
St. Jude Donor '07
you can eliminate the idler pulley and use the 'right length' belt that just fits between/around the crank pulley and the water pump pulleys.
Bill
Bill
Received 1,843 Likes
The idler pulley was added to keep the water pump spinning in the event of throwing the alternator belt in competition.
You can run without an alternator and fan but you won't get far without a pump.
PeteVS (05-25-2017)
Hi Bill, That's exactly how I'm running mine.
MikeM, you are right on about the result of throwing belts ar high r's,. Having the idler in place DOES keep that water pump running.
Jim
In God We Trust!
Jim
In God We Trust!
Received 1,974 Likes
The idler pulley is the belt tensioning element. The moveable gen/alt is the tensioning element for the other belt. As stated, some later dual pulley setups used a "captured" belt that has no tensioning element, but changing it requires removal of the water pump pulley, and it can be a real pain getting it reinstalled against the new belt tension.
BTW the sealed bearing in the idler pulley can be replaced if it goes bad - just like a water pump bearing. Give the number stamped on the bearing to a bearing supply house and they should be able to come up with a current replacement.
Duke
Duke
Correctamundo...............threw 3 alternator belts and the idler kept the pump spinning.
There were some 1965 L79s without power steering that used a "captured belt" between the crank pulley and the pump pulley with no tensioner. It was a stopgap that filled the same purpose as the idler or the power steering pump.
