Got bored today
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Brake fluid looking like its needing some attention
Well done. When mine was done last year, I found that #5 was burnt onto the that air injector tube above the exhaust manifold. I put some heat wrap on that tube along with adding heat sleeves to the end of the plug wires to prevent future damage.
Just a thought in case you want to avoid this situation
How about those front two on the passenger side (2 and 4) a lot of fun huh? I just did mine on my 49K mile 91, and the other 6 had been replaced but those two were original. I bought the car from the original owner who had all the maintenance done at the dealer, I guess he got ripped off.
I recently installed the same wire set and also NGK spark plugs on my 86. I like the AC Delco set but found that a lot of the wires were just a bit too long. Did you experience the same issue?
in fact, check out google images for what's out there...
https://www.google.com/search?q=dorm...=1496147165754
making two parts from a dorman one part...
Cjunkie (05-30-2017)
