10 rib Procharger pulley
Hi guys i'm getting a F1A Procharger kit for a ls3 c6. I want to do a 10 rib setup on it. I'll be getting a 10 rib Innovators West balancer but where can i get a 10 rib blower pulley for the Procharger?
Dallas Performance sells a 4.2 and 3.85
As Detoxx said, Dallas Performance. You need the j bracket and other parts too.
Same company. Have to call and order from them. You can use their J bracket setup or do like I did and get the A&A PC 10 rib bracket.
12 rib isn't needed
I know 12 rib will be overkill. It will be nice already having it if i decide to go crazy in the future. Seems to be the easiest way to go 12 rib from Procharger themselves. I won't have to get A&A's bracket since Procharger has the direct drive. Open thinking but it seems easier to do the 12 over the 10
Problem with 12 rib is probably availability of belts. At least 10 rib has a bunch of sizes, even though for a lot of combos the exact right size can be tough to find.
Make sure you pulley combo has a 12 rib belt that will work, or you maybe hosed.
Doesn't work that way.
Look at what is available for a 12 rib compared to a 10 rib. 5mm on a belt makes a big difference. A 4.2" pulley is going to be way different than a 3.8" pulley. Same with a 7.2" crank vs a 8" crank pulley.
Gates 12 ribs come in 3 sizes that maybe reasonable
K120525............................... 53 1/8 (1351)
K120559............................... 56 1/2 (1436)
K120594............................... 60 (1523)
Compared to 10 rib
K100535............................... 54 (1373) 40° 1 3/8 (35) K100540............................... 54 1/2 (1385) 40° 1 3/8 (35) K100554............................... 56 (1423) 40° 1 3/8 (35) K100563............................... 56 7/8 (1444) 40° 1 3/8 (35) K100570............................... 57 1/2 (1462) 40° 1 3/8 (35) K100572............................... 57 7/8 (1469) 40° 1 3/8 (35) K100575............................... 58 1/8 (1475) 40° 1 3/8 (35) K100579............................... 58 1/2 (1487) 40° 1 3/8 (35) K100594............................... 60 (1523) 40° 1 3/8 (35) K100607............................... 61 1/4 (1557) 40°
Compared to 10 rib
i saw 30 pounds off my a&a 8 rib.
