C7 Z06-it goes in to drive but car does not move?????
hello.. something just happend to me. I recentrly install headers in the z06. The thing that happen is that i took the car for the headers install and a dyno tune. The shop installs the headers the shop calls me later that the install is done buth when they were about to dyno the car at full speed when the car was going gears down a big booom was heard under the car. Now the car dose not want to go forwards nor backwards it does go in to drive but it cannot be driven. My question is why that happen?? Some people tell me is the transmission pump!!!????
Good luck.
My very first time ever modding a car I asked why they dyno the car when you first bring it in. The owner of the shop told me it has as much to do with how the car responds to mods and measuring the gains as it does that your car is sound when you bring it in. If it blows first time on rollers it's your baby if it blows after they do their thing or during tuning it's theirs.
they also know pretty close to what the car should be making power wise when you bring it in and if there's a problem they address it to you.
The shop that did my ZL-1 and my Zo6 didn't want to touch it till I had at least 5k miles on Camaro and Vette. He said if things are wrong with car they usually show themselves by then.
Good luck!
Good luck!
sounds like the shop f'ed up. Have them put the stock exhaust manifolds back on it, and reflash it to the stock tune and have it towed to the dealership while it's under warranty and hope and pray the dealer can't tell the car has ever had the ecm tuned or has been modified. Otherwise you will see dollars fly out your wallet like a million monarch butterflies in the fall.
Good luck.
Good luck.
You have voided your warranty with the tune. What ever it costs to fix is on you.
This seems to be more mechanical than tuning. The "big booom" gave it away. GL getting it resolved.
One thing is that the shop not even got the car tune is still in its original calibrations i just got the headers on and msd wires. I did some searhing and some people have told me that is the pump of the transmission and the transmission shut itself down to do no harm to the car. Right now is at the dealership but it will not get service until tusday. Dammm i miss my car
Well aren't you reacting like little miss "Polly Anna" . Personally I would never tune one of these cars. not worth the risk of catastrophic failure while under warranty. It's only fraud if the dealer asks the op if the car was tuned and relfashed back to stock and the op says "no". If they don't ask then it's not. Same as if a dealer knows about a malfunction that's covered under warranty and charges you for the repair and you don't know enough to ask. For example my dad's Malibu was just out of bumper to bumper warranty and the thermostat failed. The dealer was going to charge him and he knew enough to pull out the warranty booklet and show them the thermostat and thermostat housing is covered under the 5 year 60k power train warranty. If he didn't ask the dealer --- is that dealer committing fraud? ---no. Same with the op in this case. If the dealer doesn't ask is he going to say well maybe you shouldn't repair the car under warranty because I tuned it.
I hope he had the car put back to stock, it not GM may still void his warranty. I hope they don't void if he brought it in with the headers still on.
OP keep us posted.
OP keep us posted.
Received 1,817 Likes
What you can do AFTER you bring it back to stock tune is run the accessories till the battery dies...that will show the code they watch for when sniffing for ECM tampering the rest I can't remember...I think then you tow it in.
Running the battery down won't do anything to mask the fingerprint left from flashing the current generation of ECM, PCM, and TCM from GM (and presumably others). Powertrain group will request snapshot data when there is a major powertrain failure during warranty so it isn't the dealer that has to be fooled.
How many times do we have threads like this?
I've lost count.
For SOME reason it just never sinks in...
IF YOU MOD YOUR CAR, THE THING MIGHT BREAK.
That is it, that is all there is to it.
Come on, guys; you all know the score.
I've lost count.
same me as an insurance company. Their business is not to pay claims, their business is to collect money and to figure out how not to pay valid claims in the fine print of your contract with them.
Everything is open to interpretation and it has nothing to do with morals. It has to do with the "rule of the reasonable person" as any residing judge of a high court will state.
Although it was an issue for a number of years the manufacturers really woke up to the problem when simple changes allowed huge power increases in the new line of direct injected diesel pickups with subsequent powertrain warranty claims against the manufacturer. GM at one time provided photos of what the piston face looked like on a normal diesel pickup engine and one that had been tuned and the star or "flower petal" pattern was markedly different between the two providing clear evidence of increased fueling beyond stock. But the controllers themselves are now the key means for finding when changes have been made.
Once the cost factor from warranty claims grew large enough manufacturers became highly motivated to respond.
