Tire Gauge
Old 05-27-2017, 03:07 AM
Silver 07
Silver 07's Avatar
Default Tire Gauge
I was wondering what everyone is using for a tire gauge, trying to stay with a dial type, had a digital one, but wasn't happy with it, any suggestions would be appreciated.
Thanks
Old 05-27-2017, 05:51 AM
enventr
enventr's Avatar
Thanks
I have used a good quality dial gauge. Always check pressure when tires are cold. I check mine in the garage first thing in the morning. I have a portable air Compressor so that if it's low I can add a couple of pounds
Old 05-27-2017, 06:46 AM
NashvilleGrandSport
NashvilleGrandSport's Avatar
Same here. Analog dial gauge. Spot on accuracy. About 10 bucks or so.
Old 05-27-2017, 06:57 AM
Batman75
Batman75's Avatar
Digital. I check in the morning when tires are cold. The gage and DIC show exactly the same pressure so I don't know how you could ask for anything better.
Old 05-27-2017, 08:00 AM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
I have a couple of digital ones, but I like this dial one best:
Amazon Amazon
Old 05-27-2017, 08:22 AM
gsflyer2011
gsflyer2011's Avatar
Look for accu gauge brand. Very accurate and not costly. I have been using this brand for more than 30 years, their analog one which sells at sears.
Old 05-27-2017, 09:36 AM
Batman75
Batman75's Avatar
What is more accurate than the gage and DIC showing the same pressure?
Old 05-27-2017, 01:43 PM
Silver 07
Silver 07's Avatar
Thanks, I'm going with this one on Amazon, $14.97, TireTek Premium Tire Pressure Gauge, can't seem to find one locally.
Thanks
Old 05-27-2017, 02:06 PM
cclive
cclive's Avatar
GH Meiser Accu-Gauge
Old 05-27-2017, 02:09 PM
Seadawg
Seadawg's Avatar
I've used the DIC over the years, and used a tread depth gauge to figure our what pressure on my DIC gives even wear. Coincidentally, it is 30 psi for my vette.
Old 05-27-2017, 04:48 PM
ben z
ben z's Avatar
I've got a double-headed pencil-style pocket-clip gauge I found on the ground somewhere about 25 years ago, it's solid metal, they probably don't make that kind of quality anymore. Never let me down.
Old 05-27-2017, 05:09 PM
Silver 07
Silver 07's Avatar
Ordered the Meiser Accu-Gauge, should have it Tuesday, thanks for all the info...
Old 05-27-2017, 09:36 PM
lesooners
4th Gear
Support Corvetteforum!
lesooners's Avatar
https://www.summitracing.com/parts/lng-52053
Longacre 52053. Highly accurate, easy to use, holds pressure reading until released, usable on high pressure bicycle tires. 17 inch hose makes it easy to use. Large readable dial, rubber guard protects the guage from drops.
Old 05-27-2017, 10:24 PM
Not So Fast
Not So Fast's Avatar
Wallyworld, the Slime model, small compact and great ergonomics.
https://www.walmart.com/ip/Slime-Sho...Gauge/49802193
NSF
Old 05-27-2017, 11:19 PM
enventr
enventr's Avatar
I use an old Meiser analog gauge. Very accurate. I have had this for at least 25 years. Brass construction. I check it periodically to make sure that it's accurate.
Old 05-28-2017, 12:03 PM
unclecookie
unclecookie's Avatar
I use this digital talking gauge. I don't remember where I bought it, but it works well and is accurate.
And when I need to add air, I have this:
To Tire Gauge
Quick Reply: Tire Gauge
