Driver's Side Mirror
Anyone else having trouble with the driver's side mirror staying where it has been set and memorized? It seems about every 3rd time, or so, that mirror moves either full out or full in and has to be reset when I get in the car. Clues?
mirror issue - me too
i am having tbe same issue. i just have to take it to the dealer while it is still under factory warranty. They might not know why it is acting like this, but they will replace parts until resolved for now.
Mine does the same thing from time to time. It's irritating because it always seems to move the mirror up. Not sure it's anything the dealer is going to be able to fix, but if someone tries and they do fix it, let me know. My 2015 goes out of warranty in January, so I've got time.
E-Ray, 3LZ, ZER, LIFT
Received 9,615 Likes
Since three of you say it happens periodically-wonder if you're sure you have the same FOB each time? Just a thought.
Battery read just in the "Good" range of a quality battery tester I have used for years. It puts the battery under load when testing the voltage. Put in a new battery that read fully into the "Good" range and all was fine.
Blind spot mirror
I designed an add-on mirror that has a 3D printed wedge that gives a good angle to see the blind spot. It's a flat mirror that doesn't distort the image and works very well
That being said, very clever design of the add on mirror.
xraytom1 (05-28-2017)
