Guys what is this?
Guys what is this?
Hey lads, so i didn't drive thebcar for a few days and found some fluid on the ground. The second pic is underneath where it is dripping and lastly after a few hours. I had the A.C. on for a little but but never noticed this liquid on the ground last year. Is the A.C. unit or condenser underneath the driver door? The liquid is odorless and I think it is water but it is also underneath the brake fluid and windshield washer area as well? Any help would be appreciated.
The a/c drain is on the passenger side fwd of firewall (I think) & shouldn't drip on other parts of car, could be wrong. Just a thought, does it feel oily or slippery rubbed between your fingers? The brake line runs along the driver's side on A8 cars, have you recently installed side skirts? There is warning about not drilling into that brake line. Check brake fluid reservoir anyway, a line could have a leak I suppose. Again, if I'm totally off base I'm sure to be toasted on here but am only trying to present possibilities.
Thanks for the feedback guys, car us an M7. It doesn't feel oily and feels like water but little concerning that it is under the driver side?
My AC only drips on the passenger side.
Soak some up with a paper towel to see if it has any color at all.
The windshield washer fluid tank is right behind the left front wheel, and there is a service bulletin on some that may crack and be replaced under warranty.
Good idea will do that now because it clearly is dripping and the car has been sitting for 24 hours. I don't think it is water
In the light was able to see it is blue so you are right, thanks bud! Off she goes...but I don't drive in the rain so no rush!
