The truth about main cat deletes?
Old 05-28-2017, 07:56 AM
TRANS DAMM
TRANS DAMM's Avatar
Received 1,161 Likes on 533 Posts
Default The truth about main cat deletes?
So I was planning on buying a set of main Cat delete pipe either off the member here or I see AFE makes them now. The reviews I have read so far seem pretty good and I'm a fan due to the easier installation since I like to do almost all my own work. I already have a Corsa X and Extreme X back. Now the question is how much power am I leaving on the table by not going with long tubes. Car is a 15' Z. Current mods are exhaust/Halltech/ported TB/LMR HX/Tank. *awaiting install*IW 18 lower/e85 kit/tune. Future has me thinking of a 2.9 Whipple if I keep the car long enough. Thoughts?
Old 05-28-2017, 08:24 AM
Kracka
Kracka's Avatar
Received 5,712 Likes on 2,919 Posts
The results I've seen, added to the results of a catless X-pipe, come out to be nearly identical to full headers.
I can't find the AFE set you mentioned. Mind linking?
Old 05-28-2017, 09:37 AM
rrsperry
rrsperry's Avatar
Received 1,412 Likes on 737 Posts
It's illegal, it makes you car smell like azz, and why?
If it's because racecar.. fine, but a street car? Really? Add a sc.
Old 05-28-2017, 11:00 AM
TRANS DAMM
TRANS DAMM's Avatar
Ebay. just search C7 AFE
Old 05-28-2017, 11:01 AM
TRANS DAMM
TRANS DAMM's Avatar
I have a "sc" already. but thanks for the info
Old 05-28-2017, 12:23 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
I kind of have to agree on this. There are other ways to go faster that don't make your car smell, aren't blatantly illegal, and so on.
Heck, even removing secondary cats is probably illegal, but the main ones do the heavy lifting, let them live!
If it's about sound, that may be the only way you can get a full race sound though. But if it's about power, there are other ways. Just an opinion, not an indictment.
Old 05-28-2017, 02:14 PM
TRANS DAMM
TRANS DAMM's Avatar
Not true. Making more power creates more heat which melts the cats. I don't know of any high hp builds with cats in place.
Old 05-28-2017, 08:20 PM
Kracka
Kracka's Avatar
http://afepower.com/afe-power-48-341...nnection-pipes
At that price though, I'll wait for China to knock it off...
Old 05-28-2017, 09:49 PM
chefcg1
chefcg1's Avatar
C7 of Year Finalist (performance mods) 2019
True that! I'll keep my ported stock exhaust manifolds and go with a x-pipe for now and keep my front cats as in every car I have had I went catless and am rather tired of the smell and residue left behind.
Old 05-28-2017, 09:59 PM
TRANS DAMM
TRANS DAMM's Avatar
Lol. That was the point of the question. For not much more I could get headers but are headers going to give me that much more?
Old 05-29-2017, 04:44 AM
MerakiAutoworks
Supporting Vendor
MerakiAutoworks's Avatar
You can purchase the AFE from us.
-Josh
Old 05-30-2017, 04:58 AM
marcouvo
marcouvo's Avatar
Default Whipple
Save the $$ for the Whipple.
Old 05-30-2017, 09:57 AM
TRANS DAMM
TRANS DAMM's Avatar
I'm following the whipple closely if it ever comes out. But what does that have to do with this. Could I really push 800+hp out of the stock manifold's and cats? that's a Real Question. I am Pretty confident I would need to remove the restriction before replacing the blower.
TRANS DAMM
TRANS DAMM's Avatar
-Josh
pm me a price
Old 05-30-2017, 12:33 PM
MerakiAutoworks
Supporting Vendor
pm me a price
Please message us with the details of your car.
-Josh
Old 06-01-2017, 01:58 PM
VictorBarron
VictorBarron's Avatar
-Josh
Will using the AFE pipes throw a cell?
Old 06-01-2017, 02:37 PM
Kracka
Kracka's Avatar
I asked AFE that very question and they said it's a 50/50 chance with the high-flow catted version.
Old 06-01-2017, 03:42 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes on 2,065 Posts
2015 C7 of the Year Finalist
I thought you had to get dummy plugs for the O2 sensors?
Old 06-01-2017, 04:12 PM
Kracka
Kracka's Avatar
The tech guy I talked to there said the non-fouler trick will work to prevent a CEL if you're one of the unlucky 50%.
To The truth about main cat deletes?
Quick Reply: The truth about main cat deletes?
