Dana 44 in a 1980 but has 82 gear inside and mix
Old 05-29-2017, 04:16 AM
R6n350GT
R6n350GT's Avatar
Default Dana 44 in a 1980 but has 82 gear inside and mix
Im updating all my rear end and opened the diff to change diff fluid and check inside.
Would like to know what gear ratio this is
Where i can buy a fill plug
What oil to use, Mobil 1 75w90 fluid and how much ?
On the gear is written
Dana D 37792 A3D282 43 15
On the Cap it has OD335A
U-joint Straps bolts on diff side are 5/16" and hub side 1/4"
So are they 1330 = 1/4" or 1350 = 5/16" ??
When replacing the bushes energy suspension gave me two in the kit.
Mine needed the 1-3/4" Tie Rod Bushes not 1-1/2" if that helps
I also need a replacement diff drain bolt as someone stripped it previously
Seems i have 1982 gear someone rebuild prior
this needs to be replaced.. any idea on part # ?
other side of the cir clip
Hopefully Mike can chime in and give some guidance
Old 05-29-2017, 07:26 AM
76strokervette
76strokervette's Avatar
Gear ratio 2.87 to 1. The 1/4 bolt straps are definitely 1330 u-joints. A 1350 has 1.188 cap od while the 1330 is 1.062. Mike is definitely the man you want to talk to. If you are considering upgrades I have a 12 bolt conversion thread with pictures of new parts. I believe the first u-joint cap pictures will fit your half shafts. The outers would need the holes enlarged to a 5/16 thread which I would advise anyone to do if they are willing. They can be made for 1/4 bolts but I think most would rather have the larger fastener for strength.
If you need Mike's contact information please feel free to send pm and I will get it to you.
Dave
R6n350GT (05-29-2017)
Old 05-29-2017, 08:34 AM
R6n350GT
R6n350GT's Avatar
Dave
Thanks Dave, how did you ID the gear to be a 2.87, i thought they were 3.07. What does the 2.87 mean in terms of LS1, and gearbox choices ?
What do you mean by "I believe the first u-joint cap pictures will fit your half shafts. "
"The outers would need the holes enlarged to a 5/16 thread which I would advise anyone to do if they are willing."
Can i get new outer shells instead of drilling the 1/4" ones or are they the same size but just smaller bolts
Wonder why i have two different size u joint bolts ?
Old 05-29-2017, 08:36 AM
R6n350GT
R6n350GT's Avatar
And why does it have a 1982 in it ?
Old 05-29-2017, 08:51 AM
76strokervette
The 43 and 15 should be the number of teeth on the ring and pinion. You divide the ring teeth (43) by the pinion teeth which gives you the ratio. i believe 82 vettes came with 700r4 transmission which is how the 2.87 gear works. You can search for thread labeled 12 bolt conversion if you want to see the pictures. I know Mike would be willing to upgrade the threads for you if you are not comfortable doing it. Here is 1 picture to give you idea of difference. Making a part for the stock thread is also possible.
Dave
Old 05-29-2017, 09:00 AM
R6n350GT
R6n350GT's Avatar
Dave
Ok great thanks for telling me how to work it out.
I found it, i have a TH350C 1980 vette, not sure why i now have a 82 gear in it.
JC Turbo Hydra-Matic 350 with 305 California Engine
Whats the best trans and gear for LS engine swaps ?
Thanks again Dave.
Can we buy these new straps and i would need them for the hub side right since i have 8mm ones on the diff side ?
Old 05-29-2017, 02:27 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Received 1,005 Likes on 688 Posts
Here is a spec sheet from one of my GM 82 corvette books. Good luck with your project.
Old 05-29-2017, 02:49 PM
ddawson
ddawson's Avatar
You need to decide which transmission you plan on using so you can pick a reasonable RPM on the freeway.
No point in having a 2.87 and a TKO with a .64 OD
What you have now should have been about 2500 RPM @ 70MPH with the Turbo 350.
With everything the same but with a .64 OD you would be at 1600 RPM. I'd say even with a LS1 conversion that may be a low for the freeway.
Use the bottom part of this page to figure out your ratios,
http://www.csgnetwork.com/multirpmcalc.html
Old 05-29-2017, 09:14 PM
R6n350GT
R6n350GT's Avatar
Im not certain how to use that link yet as ui have not choosedn thwat tyres i want yet.
So lets say im going for a Gen 2 or 3 LS1 and 4L60E , what is the best gear ratio i should get. And where is the best place to buy it, what exactly do i need to replace along side the gear ?
I im a delimma, i either leave the diff as is and dont even fix it, just run it until it dies and then get a 1979 stronger diff with better half shafts ... Being in Australia the postage kills me trying to get these parts.
Suggestions ?
Old 05-29-2017, 10:16 PM
maj75
maj75's Avatar
My C5 turns about 1500 rpm at 70mph. No Problem!
Old 05-30-2017, 12:49 AM
Gale Banks 80'
Gale Banks 80''s Avatar
So it sounds to me that You have 1980 Automatic 1330 Axel Flanges. And then You have a 82 Pumpkin with 1350 Yokes. So the question is do You have the 80 or 82 1/2 shafts. On one side or another You must have Conversion U-Joints that are 1350 and 1330. In other words, somebody switched out the the Pumpkin with an 82 and they used Conversion U-Joints to make it work.
R6n350GT (05-30-2017)
Old 05-30-2017, 05:03 AM
R6n350GT
R6n350GT's Avatar
Yes your onto something there.
The U joint attached to the trailing arms have end caps measuring around 25mm for both half shaft and wheel hub.
The U joint attached to the diff side has end caps 30mm wide and the caps on the half shafts are 25mm.
So only the yokes are 30mm using the large straps.
I cant find an answer on the best gear to use with LS1 and the 4L60E. Im not sure what wheels and tyres to run. Im not doing drags, just hwy cursing and a little spirited driving in the mountains.
Old 05-31-2017, 09:26 PM
R6n350GT
R6n350GT's Avatar
need some help identifying what the part/s is that needs to be replaced as seen broken here.
Any ideas on part name, # and where to get ? Thank you!
Old 05-31-2017, 10:00 PM
R6n350GT
R6n350GT's Avatar
here is a 79 diagram, does not show the parts i need
https://www.google.com.au/url?sa=i&r...96368714097332
Old 05-31-2017, 10:23 PM
jim2527
jim2527's Avatar
My '03 had a .70 4th gear with a 2.73 rear. I hit redline on I95 sb in Dade County.
Old 06-01-2017, 02:10 AM
R6n350GT
R6n350GT's Avatar
Ok after reading this
http://www.hotrod.com/articles/gm-12...heap-and-easy/
Posi Keeper or Trac Lok Positraction Clutch Pack Retainer Clip for Corvette DANA 44 Rear
http://www.dennysdriveshaft.com/p479...action_cl.html
$0.75
Old 06-01-2017, 07:01 AM
76strokervette
pm sent
To Dana 44 in a 1980 but has 82 gear inside and mix
Old 06-01-2017, 09:07 AM
tracdogg2
tracdogg2's Avatar
Interesting article. Completely inaccurate but good pictures.
80-82 Dana D44 failures were common in the mid eighties. Lots of bad castings and machining. Most likely the original diff failed and a used 82 diff was installed.
80-81 with automatics got the 1330 u-joints with 1/4 in. bolts in the half shafts. The 4 speeds got the 1350 u-joints with 5/16 bolts. In 1982 there were no 4 speed vettes built and since it was the end of the run they used up the 4 speed stub axles, halfshafts and flanges.
The clutch plate failure is common on the 80-82. This is a design flaw that was corrected in 1985. The proper fix for an 80-82 is to install the 85-96 carrier.
R6n350GT, your clutches are damaged and so is the carrier. Replacing just the retainers won't do any good. You also have wear on the stub axles and cross shaft.
Mike
The following 2 users liked this post by tracdogg2:
bowtie racing (02-18-2020), R6n350GT (06-01-2017)
Old 06-01-2017, 06:34 PM
R6n350GT
R6n350GT's Avatar
Mike
Thanks Mike, so i didnt want to spend too much on this diff until i found better options.
Are the stub axles 100% worn or just likely to be
If rebuilding the 1980 diff are these parts what i need ?
http://www.dennysdriveshaft.com/c145...0_to_1996.html
Dana Spicer 41232 TRAC LOK DIFFERENTIAL BARE CASE fits DANA 44 rear end 1985 to 1996 Chevrolet Corvette (this doesnt use keepers like mine that broke?)
- But it says i cant use my 2.87 gear ...
Dana Spicer 707018X Positraction clutch plate kit for DANA 44 Trac Lok 1985 to 1996 CORVETTE TRACK LOCK
Dana Spicer 39194 Cross Shaft fits Dana 44 Open diff and Track Lok diff case
http://www.dennysdriveshaft.com/p107...f_and_tra.html
Side question, would a 1993 c4 corvette fit in a 1980 C3 ?
Old 06-01-2017, 06:43 PM
R6n350GT
R6n350GT's Avatar
and i would then need
http://www.dennysdriveshaft.com/p350..._ratio_ri.html
D44-354 DANA SVL 2020428 - DANA 44 Front or Rear 3.54 Ratio Ring and Pinion Gear Set
About $300 in parts excluding yolks
Quick Reply: Dana 44 in a 1980 but has 82 gear inside and mix
