Seafoam?
Seafoam?
Did a search couldn't find anything.
Would using the spray in foam not the gas tank version help remove the carbon from the intake valve on the GDI?
Also thinking about using it on my 2015 tundra with GDI. Dont want to void the warrenty but would like to keep this issue under control.
I've used seafoam on my old Volvo 5 cylnder. No noticeable impact. What I would suggest is going for a proper decarbonization where the fuel intake is hooked in directly to.. can't remember the name of the machine. A google quest may provide the name. There are a couple. The purpose built decarbonizer rigs actually give dramatic cleaning in the space of a half hour. The trick is finding a shop which has one.
Maintenance is as easy as top tier / detergent gasoline.
I dont think that system will work with the new GDI system. The fuel doesn't wash the valves like the previous setup.
JerryU (05-29-2017)
Received 1,762 Likes
Really only one way pull the intake then make sure one set of valves are closed then you have a few diff ways of cleaning the back side of the valves. Walnut's, spray & a drill with a tool on the end of it made to do the job. Then blow it out really good with air. Have to turn the engine over to get each hole valves close so the stuff doesn't go down into the top of the pistons.
I've heard doing WOT every now and keeps the carbon out.
vbdenny (05-29-2017)
I have had great luck with sea foam but I have only used it on high mileage cars that had been neglected. I did the whole system including adding to oil, sucking through vacuume line, and adding to fuel. The Sebring I did had tons of carbon build up on valves, sludge on the entire valve train and ran like crap. After going through the process it ran great valve train was clean, sludge gone and the scope showed most of the carbon build up gone.
My question is why do you think you have an issue have you used a bore scope????
The best way to mitigate oil accumulating on your intake valves is to use a oil/air separator and catch can. Note I said "mitigate" not eliminate. After 20k miles, it will be best to do a visual inspection of the intake valves and if they look less than optimal, mechanically remove the accumulation and you'll be good to go. If you want to go the extra mile, use some Seafoam after you mechanically clean the valves.
Top tier is a marketing ploy only anyway.
The following 2 users liked this post by fnbrowning:
Foosh (05-30-2017),
yeller z06 (05-30-2017)
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Only air and PCV "stuff" (that causes oil to bake onto the hot intake valves) goes through the manifold and past the back of the intake valves. Nothing added to gasoline, which only goes into the combustion chamber, helps the back of the valves from what is called "coking."
Top Tier is NOT a marketing ploy! Gas that meets the criteria must have a minimum amount of cleaning additive, that helps keep the injectors clean and to some degree combustion chamber carbon build-up. It also helps keep sulphur in gas from fowling the fuel level sensor.
Per the Owner's Manual, for the times I don't use Top Tier and to get some extra help in preventing the sulphur in gasoline from fouling the fuel sensor I use the GM equivalent of Seafoam at every oil change. (Believe the GM product is Techron relabeled, which is similar or the same as Seafoam.) It helps desolve sulphur deposits.
There have been forum posts where a dealer used several containers of the GM product to solve the fuel sensor issue. Other posts where they replaced the sensor. That requires removing the two gas tanks and crossover pipe, which requires dropping the drivetrain! That poster was horrified to see all this "stuff" on the dealers shop floor! If past warranty, very expensive! One container per oil change provides some preventative insurance!
Thought Seafoam was the same. I pay a bit more and by the GM product but think I will switch to cheaper Techron.
The stuff works pretty well for some things, but I don't know if it will reduce carbon buildup on the valves in a DI engine. Otherwise, you'd think all of the manufacturers would recommend it, right?
Additives
I'm not a firm believer in additives but working as a technician for 30 plus years Techron, SeaFoam, & Rislone work wonders when decarbonizing the upper end. Also water injection works just like Steam Cleaning parts. Have you ever seen an engine taken apart after a blown head gasket? The cylinder that had the bad gasket the parts piston and valves will be spotless. Some additives work but I feel the same if it was that good why doesn't the factories install and recommend them.
I've read the MSDS for the product, and there is nothing in it that came from the ocean, be it seaweed or any kind of foam.
Early on Ferrari indicated they might use a flush system through the intake annually or periodically. As I recall it was too little too late. Once the carbon bakes on only mechanical means can get it off.
