FS: Project Clean-Out - Performance Parts & Misc
Running Guns & Moonshine
Last Updated: 07/09/2021
The thread began with one blower project car and is now on the second blower project car.
Some items are take-offs, others are new in box, spare, and some are installed but never run and already being upgraded. Save a few bucks instead of supporting Amazon.
Brand New
$125 – Earl’s Perform-o-Flex 20ft of -6an (purchased for AIS methanol tank)
$110 -- Motion Raceworks coil bracket for IGN1A smart / Holley coils anodized black. (Did not fit intended location when mocked up.)
$50 -- LS2 Timing Cover. Gasket and bolts included. (Spare - bought as kit with sensor for a special price, kept the sensor though! LOL)
$40 -- Fuel Pump Hat Gasket for 97-99. Each includes with 6 new bolts
Used Parts - from 2003 Z06 with 62k miles unless otherwise stated:
$110 -- 8x coils with harness & valve cover brackets
$95 -- Black Center Console Bezel from 2003 Z06, near perfect condition missing only the screw hole over the air temp.
SOLD - AIS / Prometh Trunk Mount Stealth Methanol Tank
SOLD - A&A Vortech Supercharger Bracket
SOLD - TR6060 MZ6 with 3.42 differential from 2012 GS w 3000 miles
SOLD - ECS Trans / Diff Brace for Manual C5
SOLD - D585 coils with Michigan Motorsports adapter and extension and ICT remote mount bracket
SOLD - TSP LS6 modified / high flow oil pump
SOLD - 2x C6 rear sets of upper and lower control arms
SOLD - 2x HID ballasts
SOLD - 2x C5 Steering Knuckles with sensors
SOLD - Edelbrock LS1 / LS6 two-piece timing cover 31-4254
SOLD - AC Delco Water Pump #252-846 with 160* Thermostat
SOLD - BTR Cam Installation Kit
SOLD - 12603782 - engine oil level indicator
SOLD - 12585546 - crank position sensor for 58x reluctor LS
SOLD - 12mm Driveshaft
SOLD - D580 coils with harness and bracket
SOLD - Tick Remote Clutch Bleeder
SOLD - Siemens Deka 60lb Injectors
SOLD - LS1 Head Gaskets 12498544
SOLD - LS6 Fuel Rail
SOLD - Speed Bleeders sb1010s-b
SOLD - LS6 Timing Cover
SOLD - C5 Z06 complete brake set
SOLD - Tick Adjustable Master
SOLD - Johnson 2110R Lifters
SOLD - F.A.S.T. 92
SOLD - LS6 Rockers & new Straub Bushing Kit
SOLD - Proform Dual Gauge B-Pillar Gauge Cluster
SOLD - LS2 Throttle Body
SOLD - Halo LED tail lights
SOLD - ACA headlight kit with Morimoto ballasts
SOLD - Racetronix Walbro 255 fuel pump
SOLD - LS2 90mm TB
SOLD - Sac City Align-It Tools
SOLD - Comp Cams Trunion Kit
SOLD - Caspers Hot Wire kit
SOLD - LS6 Valley Plate
SOLD - Lowering bolts
SOLD - Z06 style fog mesh inserts
SOLD - Z06 trunk hinges
SOLD - Proform LS spring compression tool
SOLD - Skip-shift eliminator
SOLD - Katech manual tensioner pulley
SOLD - LS1 factory accessory bracket
SOLD - 1999 F45 Trunk-mount computer & all 4 sensors
SOLD - LPE LS valve spring compressor removal tool
SOLD - Comp Cams Trunnion Tool
SOLD - OEM PS Pump
SOLD - Kenwood KIV-BT901 with custom surround plate
SOLD - Axxess XSVI-2004 stereo interface
SOLD - PAC ADD-VET1
SOLD - A&A Supercharger MAF coupler & LS7 MAF
SOLD - LS2 Timing Chain
Brand New
SOLD - F.A.S.T. 92
SOLD - LS2 90mm TB
SOLD - OEM PS Pump
SOLD - PAC ADD-VET1
Friday morning bump. Several items in the air, but not committed to yet.
Sunday bump.
$100 - Comp Cams Trunion Kit (NEW IN BOX) needle bearing type? or the solid bushing?
Friday bump.
I'll be down tomorrow or sat to check the Comp box for part numbers, etc.
$20 - LS1 factory accessory bracket - perfect for cleaning and painting now, then replacing your existing bracket all in one shot. I bought a new one to do just this. My plan is next to rip the alternator apart and paint the housing to match. The engine looks MUCH cleaner with these parts painted a simple crinkle black. Does this bolt to the front of the block to mount the PS, and Alternator? send me a pick and I'll take it. Ron B.
Yes. The power steering pump and alternator would connect to this piece. I'll be down to the car tonight or tomorrow and will grab pictures for you.
Shipping to Spearfish SD 57783 for the alt-ps bracket? PM price and Did you find out if the comp rocker kit was solid bushing or needle type. Thanks Ron B.
Ron, make it $35 shipped for the bracket. The comp kit I never found out, already sold. I'll pm you details.
Paypal sent, covered your fees. Thanks Ron B. PS do you make it to the Black Hills Corvette Classic in Spearfish SD?
Never heard of it. I've had friends in ND at Minot, but I've only ever been through Minnesota and Iowa in that general area.
For the shocks, they're of a size and weight where distance may make such a deal a no go. What zip code would they go to? I'll check shipping expense.
