Passenger side door from an 86. No damage. Newer scissor style window regulator, power door lock actuator, speaker, complete uncut wiring harness (from front to back of door), and glass are all there. Glass is perfect. No scratches. Tested and everything works. $160. Local pick-up only. If you're only needing the shell, I will separate the glass and regulator and sell it for $60. Located in Milton, Pa.
Reason: Putting the drivers door on as well
