Plastic vacuum lines!!
Most all parts stores sell either bulk (cut to length) or carded vacuum hose in a variety of inside diameters. You can also get plastic couplers, tees, and 90 degree fittings in various diameters. Get about 50% extra in the length of the rubber lines to make sure you will have enough.
Guess you could get some small diameter tubing, and bend your own, with rubber couplers on the ends. Not sure why you would want too though...just an idea.
D.
D.
Replacement plastic tube has not been available for years. You can buy plastic tube from some places, but it is a PITA to bend (have to heat). As noted above, it is easier to buy vacuum tubing and use that.
I tried that on another car with those plastic lines and finally just tossed that new plastic stuff in the trash with the old and went with small dia rubber hose and little plastic end connectors. The plastic tubing was impossible to keep from coiling up. It was like trying to work with prison fence barbed wire!
C4 of Year Finalist (appearance mods) 2019
a dozen years ago when I first bought the 95 I ended up having to replace several of the plastic vacuum tubes and in the process I decided that I liked the way the engine looks with the fuel rail covers off. I've left them off ever since.
It's been more than 100K and they are in great shape and I wonder if perhaps ... having the covers off allows those plastic pieces to stay just marginally cooler or perhaps cool off sooner not being under the additional layer of the covers?
As I say you have to like this look and for me it works.
I haven't had time to replace them yet but am definitely going back with rubber.
Kinda off topic but does my 90 supposed to have fuel rail covers?? I am missing the distributor cover that a PO removed and never put back. All of my injectors and fuel rail are exposed.
Thanks
Wade
Thanks
Wade
I have been thinking about using some small diameter tubing, like brake lines.
i have also seen brass and aluminum at hobby stores.
Anyone ever use silicone tubing?
I saw some being sold on amazon, i have been thinking about giving it a try...
I need to make a new run from my fuel pressure regulator, back to my brake booster line...
a tubing bender specifically for 5/32" aluminum or brass tubing. you could use the existing couplers, and if you wanted a more correct look, a coat of black etching primer.
Paul Workman (10-26-2018)
1989 C4 brittle vacuum lines
Thanks for this thread. 89 C4 L98 running wonky, hunts RPM at idle, some hard starts. Advised to clean throttle body... OK but then every plastic line I touch breaks. I like the idea of alum bent to fit, joined with rubber hose. Found some on amazon along with
. Worth a try. My lines that broke are mounted to a bolt right under the throttle body, I think to do with fuel pressure regulator? Have not been able to find them in the FSM so far.
Old coupler where line sheared off and adjacent line with PO repair. These head up to a cannister in the front
Mount for two lines? I think, under the throttle body. These things are super brittle. At least one of these seems to head off to a canister in the LF nose area.
No thanks; I have them stored along with the car's original trans, exhaust manifolds, cats, etc. I have the room so don't really need to dump them. I thought that you were selling your C4 to get a C5?
Thanks, I'll be selling mine in a couple more years, waiting till it hits 25yrs old.
