FS: 1971 Convertible Oklahoma $25,000
*** Sold 12/26. ***
1971 Corvette Convertible.
https://dallas.craigslist.org/dal/ct...403489449.html
350/700R4 automatic overdrive....Monster Trans Heavy Duty 700R4 overdrive ***see engine specs below...added 7/18/17**
Mean, low, fast, and Loud!
Great reliable street machine.
Frame isn't rusty
Windshield frame and birdcage are clean as well.
clean vin and trim tag
Nice soft top, clean black interior, high back buckets with good lateral support.
tilt tele steering column.
This car had had lots of money spent on it.. VBP fiberglass rear spring, offset trailing arms, spreader bar, RACK AND PINION..
Wilwood brakes..Detroit Speed electric headlight motors..recent suspension bushings, new carpet. This list goes on. Very very nice driver quality paint..
Starts right up every time, runs and drives very well.
all gauges work as they should,
hushmat installed under carpet
Detroit Speed headlight motors
Z51 front springs
Bilstein shocks all around
NEW brake lines
NEW master cylinder
NEW water pump
Twin electric fans
Gary 918-704-0277
g.guinn@maccor.com
Frame isn't rusty
Z51 front springs
NEW brake lines
NEW master cylinder
NEW water pump
Twin electric fans
Gary 918-704-0277
g.guinn@maccor.com
Last edited by garyguinn; 12-26-2017 at 11:35 PM. Reason: Corrected spelling of Wilwood
Killer Instincts (07-12-2017)
Received 2,878 Likes
Hi gg,
Striking looking car!
But not even a hint about the engine beyond it being a 350?
Regards,
Alan
Regards,
Alan
Thanks Alan..
Non matching 350.........updated 7/18 with the engine history I found ...note...I did not install this engine...this
is the engine in the car when she made her way to my place....
"the NEW engine is a small block 350 that has been bored 30 over to make the displacement a 355 C.I. Starting with the bottom end, it has a steel crank and steel connecting rods. The pistons are JE Forged 10:50 compression ratio with chrome molly rings. It has a SF flywheel and a new harmonic balancer. Everything in the bottom end has been balanced. The heads are angle plugged GM with 202 valves (Manley valves), triple valve springs, screw in studs and Crane Gold roller rockers with stud bar rocker locks. It has a Competition Cams camshaft, C class hydraulic flat tapped with 487 intake lift and a 501 exhaust lift (nitrous cam) with a standard double roller timing chain. The intake is an Edlebrock torker style with a 650 mechanical seconds Demon carburetor (double pumper) with no choke (All New). There is also an MSD HEI replacement distributor"
Have info on cam card.. no wild guesses on horsepower
Or torque.. she has plenty of power.. starts,runs, and drives very well..
I'll get casting number in the morning
Gary
Dwight007 (07-12-2017)
Really, nobody?
should I cover this ugly beast with a tarp and shove it back
in my garage?
in my garage?
Detroit Speed electric headlight motor actuators. work well
Nice soft top
I've seen this car. It has great bones. Any of the mods on this car you don't like are easily reversed.
You can buy with confidence from Gary. No misrepresentation here. Good, honest cars from a good, honest guy.
Carter
Carter
jon c (10-14-2017)
Received 3,043 Likes
St. Jude Donor '05
Try ebay
youll always get the Dbag who wants to criticize your car...of course if you took a lowball then its fine. Been going through that for a year finally took it off the market.
Good luck!!
Black sidepipes really growing on me has a nice hotrod flavor to it.
Good luck!!
