Z51 tires for track days
Looking at tires for my stock Z51 wheels. These will be 90% track use only. The other 10% might be driving to/from the track, hotel, etc. From what I can find, the following tires are available in the correct sizes. Looking for comments from those with experience with these tires:
Michelin Cup 2, $340/$533
Bridgestone RE71R, $302/$337
I've been running the Bridgestone S-04, with the rear in the 295 size versus the stock 285. The Cup 2 and RE71R are also available in the 295 size.
Overall happy with the S-04 for what they are a high performance street tire. As my lap times have improved, I am over driving these tires, and need something closer to a pure track tire.
The corvette suspension is setup for the stiff runflats it seems, so going to different tires may not be an immediate improvement. Also, the regular cup 2s are VERY different from the cup 2 RFs that come on the z07 packages, look at the pictures on tire rack. Cup 2 RFs are basically half slicks, half normal cup 2.
I am in the same boat as you but 50% track 50% weekend driving and likely will go back to the stock tires because I don't want to buy different wheels to just go up 10 or 20 mm in size (can't fit much on the narrow body corvettes without rubbing or sticking the tires out a lot). If hankook was kind and sold 295/30R20, I would probably get them. They communicated well and didn't fall off at all. Problem is they were narrow and the rear tire being a 285/35 made me have to lift the rear suspension all the way up (still was able to get -1 camber though)
According to tire rack, regular MPSS tested better than the S-04 in pretty much all categories. All in all, i'd rather have a consistent 20 minute session tire like the hankooks than a faster 3 lap tire.
Also any problems with running the wider rear? Lowered all the way? what width in the front?
Neither MPSS or S-04 are track day tires. It's very easy to get them past operating temp and they certainly won't be consistent from lap to lap, due to heat, after your first track day or two. They're phenominal street tires, but they just aren't anywhere near track tires.
With that said, I'm going out tomorrow on my MPSS because I'm dying to try the new GS out, but I'm willing to bet I can get 2 laps, max, running at 80% (track day pace) before they're oily and crap. I'll probably be running at 50% out there all day.
The S-04 are getting greasy as my driving improves. To be fair they are about half worn.
From what I read on reviews here and elsewhere, both the Cup 2 and RE71R begin to fall off after a few laps. I guess its a matter of perspective compared to what? Compared to perfection, maybe. Compared to street performance tires, probably. I have to think that the Cup 2 and RE71R will tolerate the heat better than any of the alternatives.
The RE71 is available only available in one size larger, but when you look at the actual measurements they are almost identical to the OEM size Goodyear. For the front the RE71R is available in 255/35-19, two sizes larger but again in actual specs its a small difference. It appears the Goodyear tires physically larger than other brands of the same size.
The new Michelin PS4S is available in both original Z51 size, and one size larger front and rear. Cost seems to be about the same as the PSS. An online interview with Michelin said a new version of the Cup 2 is under development because the performance of the PS4S is so close.
Sr.Random input generator
In my experience, RS3s did not get greasy, and they were somewhat consistent at the track thoughout even long sessions.
I think your real problem is the fact that you would like to use 19"/20" OEM wheels, which limit your choices. Once you go down to 18"/19" sizes (like base Corvettes until '17), you will have many more choices.
Going back to the question, NT01s seem to be great tires for track use, since they're pretty cheap, yet provide near-r-compound traction without much warm-up required. They're also pretty good at the streets; just don't drive it if it's raining hard, or through the puddles : )
Have had good experiences with triple 8's and NT 01's on other cars but sizes are pretty limited for the C7.
Does anyone have experience running a square setup in 18 or 19 sizes? Or, has anyone had experience with a staggered 18/19 setup that clears the Z51 brakes?
Have had 1 track weekend out at Inde Mortorsports Ranch in Wilcox AZ and was surprised by the handling and wear of the MPSS's but would really like to get something a little bit softer in a "non-run flat" tire.
Suggestions would be appreciated.
I use CCW TS12 wheels at 18x10.5 +51, 19x11.5 +83. Not just Z51, they even clear Z06 brakes, even CCBs! They're also rated at 3000 lbs load rating; you can't find many wheels in the market with such a high rating.
Thanks X25. What size tires/brand have you run? Any clearance issue (rubbing/sticking out)?
Notice you're from Redmond, WA. Moved to Tucson from Kenmore, WA. Used to do a bunch of track work with PCA, BMW, Audi, & Turn 2 at SIR, The Ridge, Oregon Raceway Park. Really miss the car community up there, particularly the track junkies.
The C6 Z06 rear wheel is 19x12. Thats two inches wider than my C7 Z51 rear wheel. Sounds like just asking for clearance problems.
If I was going to use 18" front/rear to get more tire selection, is there an OEM take off from another model that would be correct, or would that be custom? I don't know much about how to specify the correct offset, or make sure I am buying the right thing. The tire part is easier, just go to the tire manufacturer specification charts. Wheel offset I'm a bit lost.
I'm using PS4S this season.
They are much, much better on the street than PSS RF (no chatter when cold, quieter, smoother). They are slightly better than PSS RF on track from a grip standpoint, but they are measurably better from a wear and heat tolerance point of view. I think I may be able to get almost 50% more track day miles out of them (6-7 track days vs 4-5 track days).
As they wear they become squealers on track - makes you sound like the beginners that go understating through the turns, but the squealing does not seem to accelerate wear or overheat them. I wonder if anyone else has notice the same thing as they get to the last 1/3 of their useful life.
P.S. Obviously, the downsize is that if you have a flat tire, you are done. I carry a compressor, sealant, plugs, but I know those things are often useless for the types of flats we tend to get - usually cut sidewall from the giant northeast potholes.
Citation, you & I are trying to do the same thing: better tire selection while running wheels that won't create problems with clearance. Other important factor to consider is overall diameter to appease the "nanny gods" so that you DON'T get all these warnings or limp mode. (yes, I still use nannies. Track sport 1 setting)
Just did autocross for the first time today on stock MPSS RF 19/20 sizes. I did decent for a first time but there was another C7 there that destroyed my time. He is a much better driver but he was also running some bridgestone Pole positions (I think). I'm sure he'd make better times in my car (driver mod) but he said the tires definitely help and I'm a believer. I like the MPSS on the street but for autocross, especially a miata club event (smaller track), there was room for improvement on traction.
I did run NT02 275/35/18 and 305/30/19, and had no rubbing issues, anywhere. Later, I switched to 315/30/18F 325/30/19R tires, which didn't rub at the street, but all four corners rubbed at the track due to additional traction causing too much lean in corners with stock suspension. I switched to much stiffer LG G2 coilovers with LG sway bars, and problem was solved again, along with a big drop in lap times.
Regarding C6 or C7 Z06 wheels: their offset are for wide body, and they will not fit (they will stick out by about 1"). You can use my wheel specs as a starting point (don't stick out more than my wheels, since the spec keeps the wheels as much outside as possible to maximize inside clearance with my rather wide wheels).
The Toyo R888R are available in the correct Z71 size for the rear, but the front only comes in a 235/35-19 instead of the stock 245. Looking at the actual tire manufacturer specifications, the Toyo 235 is only 0.3" narrower and 0.3" less diameter.
If I go with the RE71R, I can go to a 255/35-19 front and gain 0.4" width and only pick up 0.2" diameter. Those are small amounts but compared to the smaller R88R thats 0.7" difference in width, a significant amount.
The stock rear size is 285/30-20. The MPSS, Cup2, and RE71R all come in a 295 which is 0.5" wider, but only 0.2" more diameter. Again these are tire mfr specs.
I'm going to give the RE71R a try. I think they'll do as well as the Cup 2, and are a lot cheaper. I respect that some say the RE71R fall off when hot, but thats got to come at much higher temps than the S-01 I have now, or the MPSS. I've read similar comments on the Cup 2. Lets face it these are not pure race tires.
We don't have choices for the 20"rears. that's the problem. Need to do 18/19. I really wish I didn't have to buy wheels because the z51 wheels are so nice but it seems that's the only choice for track day tires.
