C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Trying new airboxes and intake on my z06 with the Harrop Hurricane
Old 07-17-2017, 10:03 AM
ibp1012
ibp1012's Avatar
Default Trying new airboxes and intake on my z06 with the Harrop Hurricane
Just wanted to show some people what I have been working on, to make the Harrop Hurricane work in a c6 z06. The airboxes are made of carbon fiber and I moved the alternator around this time, to have enough space for everything. Hope you like it!
Old 07-17-2017, 10:08 AM
LFZ
LFZ's Avatar
The following 2 users liked this post by LFZ:
Ghost Knight (07-29-2017), HC Mechanic (07-30-2017)
Old 07-17-2017, 10:45 AM
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
Nice work!
Looks very similar to what my friend, Heinz, in Austria did a few years ago at Cool Chevy Race Parts.
Old 07-17-2017, 11:31 AM
Lawdogg
Lawdogg's Avatar
Very nice looking setup!
Old 07-17-2017, 11:32 AM
ibp1012
ibp1012's Avatar
Originally Posted by HP RESEARCH
Nice work!
That's probably no coincidence as I designed that system as well . Heinz did the tune and install on that one as well as this one. Back then he needed to work out a speed density tune, today we run 100% on the MAF which makes life much easier.
We had a few issues with that design, that's why I revised it. Now we have 4 inch round inlets on either side which also makes performance better compared to the oval inlets.
The following 2 users liked this post by ibp1012:
HC Mechanic (07-30-2017), HP RESEARCH (07-17-2017)
jayyyw
jayyyw's Avatar
What's the issue with running this intake in our cars?
Old 07-17-2017, 11:45 AM
0HP RESEARCH
Former Vendor
Nice! I had sent Heinz a email the other day as I have a friend here in the states that is looking for one here state side. Maybe reach out to Heinz and ask him about it if you have a few pieces laying around.
Old 07-17-2017, 11:56 AM
ibp1012
ibp1012's Avatar
Well besides that there is barely any space to fit airboxes that won't either touch the valve covers, the alternator, the hood, or the firewall, there is no Corvette specific issue. Without airboxes they don't produce power though as they suck in hot air from the engine compartment and you loose a lot of power. Other than that the Hurricane works great and produces tons of torque just like it would in any other setup.
jayyyw (07-17-2017)
Old 07-17-2017, 11:57 AM
ibp1012
ibp1012's Avatar
ok will do, he might have something laying around I think...
Old 07-17-2017, 03:12 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Sick!
Old 07-17-2017, 04:07 PM
ibp1012
ibp1012's Avatar
Originally Posted by MTPZ06
Sick!
Thanks
Old 07-17-2017, 04:15 PM
MTPZ06
MTPZ06's Avatar
Thanks
Any other mods to the car? What kind of power is it putting down with the Harrop?
Old 07-17-2017, 04:26 PM
ibp1012
ibp1012's Avatar
Yes, I have forged Mahle pistons on the lower end, Katech valve train and K501 camshaft, milled heads to 11.5 CR and American Racing Headers 1 7/8" going into a Corsa exhaust.
I'll post before/after numbers next week after the dyno session. My old setup showed some nice gains, and this setup will definitely outflow it so I'm hoping for something quite nice for a NA mod. The car does feel like as if it had a small supercharger with the Harrop though, there is that much more torque available from 3000 RPM.
The following 4 users liked this post by ibp1012:
FNBADAZ06 (07-17-2017), HC Mechanic (07-30-2017), MTPZ06 (07-17-2017), Suns_PSD (07-17-2017)
Old 07-17-2017, 07:10 PM
FNBADAZ06
FNBADAZ06's Avatar
sub'd
Old 07-17-2017, 07:42 PM
Josh B.
Josh B.'s Avatar
No words could describe how sick those intakes are. So much want.
Old 07-18-2017, 08:48 AM
ibp1012
ibp1012's Avatar
Thanks . I hope the dyno numbers will back up the looks!
Old 07-29-2017, 10:24 AM
ibp1012
ibp1012's Avatar
So here are some preliminary dyno plots. We gained about 10-20 hp nearly everywhere, depending on RPM. However, compared to my old setup, which was in one of the images posted above, we lost 20-40 hp depending on RPM.
I did some CFD to resolve this issue, as the airboxes are actually better than the old design. It turns out that the hoses have 10% momentum (mass flow) loss compared to a straight pipe of equal diameter and length.
I figured that I would have losses with the hoses, but I was thinking on the order of 10 hp and hoping that the better airboxes would make up for that. Far from reality
Therefore I will make a carbon filter box, similar to the old design and we should be back on the amazing gains we had previously. On the old run, the throttle was released around 6200 RPM as our rear seal blew that time, so that's why the dyno goes down drastically towards the end. With the new setup we should have 10-20 hp on top of that above 6200 RPM.
Josh B. (07-30-2017)
To Trying new airboxes and intake on my z06 with the Harrop Hurricane
Old 07-29-2017, 11:43 AM
meanjoe
meanjoe's Avatar
Badass!!
Old 07-29-2017, 04:31 PM
MTPZ06
MTPZ06's Avatar
Originally Posted by meanjoe
Badass!!
Old 07-29-2017, 11:53 PM
atljar
atljar's Avatar
Don't want to put words into anyone's mouth, but I believe Jim halltech and katech didn't have the best results with this intake either, and ended up switching back to a standard composite setup with 1 TB. That too was on k501 cam and higher compression
Quick Reply: Trying new airboxes and intake on my z06 with the Harrop Hurricane
