C7 RKE (Key Fob) are they all the same 2014-2018?
Old Jul 18, 2017 | 10:39 PM
Mr. Knowitall's Avatar
Mr. Knowitall
Default C7 RKE (Key Fob) are they all the same 2014-2018?
RKE key fob for the C7, are they all the same for 2014-2018? I'm thinking about buying a third just in case, looking on fleabay, and many of them are listed as 2014-2016 for example.
Are there any gotcha to buying and DIY programming a used rke key fob?
Can I program a 2nd rke if I only have 1 functioning rke?
Thanks.
Old Jul 19, 2017 | 12:11 AM
CP's Avatar
CP
Thanks.
I was told that a used RKE could not be programmed to another car. This came from a Chebby dealer after spending a lot of time trying to program an RKE I got used. Had to buy a new one and get that programmed. That worked.
Old Jul 19, 2017 | 03:21 AM
Kent1999's Avatar
Kent1999
Pairing is exactly the same for used or new fobs. Neither the car nor the fob know the difference.
Unless you are in Canada, you have 2 choices:
1) If you have at least ONE working fob, you can do the "short" pairing to just add the additional fob, leaving all other previously-paired fobs operational.
2) If you have NO working fobs (or you have lost a fob and you want to make sure that if someone finds it, they cannot use it on your car), you can *only* do the "long" pairing method, which 1st de-pairs ALL known fobs, and then lets you re-pair each one from scratch. There is no way for the owner to "de-pair" only a single lost fob, and leave the other known fobs pairing intact.
FYI -- There are those who unfortunately have had legitimate difficulty pairing used fobs (such as the poster above), but there are also a lot of us here who have experienced absolutely no issues pairing additional "used" fobs with our car. There is no official rule from GM that only "new, never paired" fobs can be used on your C7.
Old Jul 20, 2017 | 10:48 AM
RonC7's Avatar
RonC7
Just be sure to get the correct fob.
There are 4 flavors:
- manual trans, coupe
- manual trans, vert (has vert top button)
- auto trans, coupe (has remote start button)
- auto trans, vert (has remote start & vert top button)
Old Jul 20, 2017 | 07:44 PM
Mr. Knowitall
Can you use an auto vert fob with a manual coupe and just have 2 non-functions buttons?
Can you use a manual coupe fob with a auto vert and just not have remote start and top down functionality?
Old Jul 20, 2017 | 11:24 PM
owc6's Avatar
owc6
True, because you technically aren't programming the fob, you are programming the car (to recognize the fob). "Programming" changes absolutely nothing about the fob, so new or used, the fob is exactly the same. The car only knows if it recognizes the fob, but doesn't know if other cars may recognize the fob.
This just made me think of something, and I don't think if anyone has brought it up before. Theoretically, if you own two C6s or two of the same type C7s, you could program both cars to recognize all the fobs you have ( up to four on the C6, or up to 8 on the C7). That way, you only have to carry one fob and could access both cars with the same fob.
Old Jul 20, 2017 | 11:39 PM
Mr. Knowitall
So...biggest point for me...there is no need to buy a 'spare' fob now because I can always reprogram a second if I still have a key.
I was just looking through the manual on how to pair with 1 or 0 fobs present. It says you need a key. My only 2 keys are inside my 2 fobs. So if I lost them both...I'm guessing a trip to the stealership is required. Can I have a hardware store make a copy of the key from my fob on to a regular old metal key? Then I could use that key to pair new fobs if I somehow lost all my fobs at the same time?
Old Jul 20, 2017 | 11:44 PM
owc6's Avatar
owc6
If you have an existing key, anyone who has the correct (very expensive) machine can cut a copy for you. If you don't have a key, only a GM dealer can legally cut you a copy using your VIN, and you need to have proof that you are the owner. Even now, not every dealer has the machine needed to cut the key, so they may need to order a cut copy from either another dealer who has the machine, or GM directly.
Old Jul 20, 2017 | 11:51 PM
Mr. Knowitall
Where might I find somebody with such a key making machine? Locksmith? Or only dealers?
Old Jul 21, 2017 | 12:04 AM
owc6's Avatar
owc6
Laser-cut keys are becoming more common (or technically less-uncommon ), so, I would think that more and more locksmiths are acquiring the machines to do them as well.
Other brand dealers, perhaps, as well might have such a machine(?).
Either way, you will need a proper blank (available from many sources), just as you would with any metal key.
eta: provided you have a key to copy.
Old Sep 11, 2017 | 07:31 PM
VETTE-NV's Avatar
VETTE-NV
16 Vettes and counting…..
Apparently the short method will not work on a 2017. I have one recognized remote, however the car will only allow me to do the long method. The manual says that TWO recognized remotes must be present to program an additional remote via the short method.
The guy in the service dept of my local dealer told me that the DIY method will only work with a key fob that has lost its programming...not a brand new remote. Seems to me that the car is the thing being reprogrammed, not the key fob....how can the key fob lose its programming?
Old Sep 11, 2017 | 07:55 PM
owc6's Avatar
owc6
You are correct, the car learns the fob, the fob remains unchanged. Fobs cannot lose their programming. I have never heard of a fob legitimately becoming unpaired with a car. There has always been some other reason if a fob quits working.
I suspect a change in the car is the difference in the new two-fob needed change in programming. I bet the fobs are still the same.
Old Sep 11, 2017 | 10:43 PM
RonC7's Avatar
RonC7
Realize that if you ADD a fob, it becomes #3 so it will not trigger seat memory. If you want it to REPLACE #1 or #2 you must use the long procedure which wipes fobs from the car's memory. The first fob you match to the car becomes #1...
Ron
Old Yesterday | 08:39 PM
dnapowersports's Avatar
dnapowersports
3rd Gear
Ron
JESUS - NOTHING works. Heres the story. I had two fobs when i bought my 2017 C7. One I lost. I still have one that works. I bought a new OEM key fob for $100 on EBay. Why is it so impossible to just program my new fob? I do the whole 5 xs with the trunk and the dash says "REMOTE LEARN PENDING PLEASE WAIT" Than it goes dark. NOTHING NADA. I wait 10 mintues. NOTHING. Isn't it supposed to say press engine start at some point? I tried this with my old fob in it, my old fob nowhere near it, my old fob in the steerin wheel, the new one in it. etc etc etc. Ive tried every damn thing suggeted by 100 websites and all I get is REMOTE LEARN PENDING PLEASE WAIT than nothing. My manual says just wait 10 min - but 20 can go by and nothing ever comes up again. I have new batteries in both fobs. How can this be so danmn hard? Why cant i get past step number 1?
To C7 RKE (Key Fob) are they all the same 2014-2018?
