i think i got mold poisoning from AC vents
noticed this urine type of smell after turning the ac on for 10 seconds then it goes away. I feel like its because i put it to recirculate mode all the time in the humid weather. if i put it to outside air from now on will it go away? i got shivers, some night sweats and upset stomach. the system is not clogged since i see the water under the car once it is turned of but i believe the recirculate option caused this
put your windows down, remove the cabin filter. turn the fan on high and spray a bunch of lysol disinfectant in the cabin air intake. I have done this before to remove smells from the A/C.
The product for cleaning the evaporator box is Kool-it. Go to their website for a full explanation of how it works.
Received 3,611 Likes
2016 C6 of Year Finalist
What doesn't kill you makes you stronger.
The following 2 users liked this post by dr_gallup:
Evander Holyfield (07-22-2017),
g23crawler (07-21-2017)
Could be. I haven't driven my vette for about 4 weeks. Got in and man the smell from ac vents stunk. I opened windows for a while, went away. My weather here is real dry though, about 7% humidity. Man I love this weather here compared to Miss. and Louisiana. Tried to get here when I was 16, finally made it at 60!!
Received 1,636 Likes
Well, he won't really be able to prove if all those symptoms were related to the car. I get all those symptoms when I find out my wife's family is planning an extended visit. (Lawsuit is not an option in my case)
The following 2 users liked this post by TorchRedFred:
SPSandman (07-18-2022),
Virtual Geezer (07-21-2017)
Received 3,066 Likes
Yup, gotta love the weather in California ... But I am betting you don't much love the high taxes there. I am thinking you don't much love the requirement for a front license plate either.
Received 3,043 Likes
St. Jude Donor '05
Change your cabin filter, get some vent cleaner in there and go see a Dr.
May be something else you dont want to put off.
I like to turn off the a/c compressor and run the fan only for 30 seconds or so to dry out the condenser before I pull in the garage and shut off the engine.
Now the traffic in LA is horrible, but not so several times a day. Gasoline is $2.59, so that's higher here too. Huuuuh phew, that was lung full. Sorry for the change and I know it's far from the OP subject, but you brought it up LOL
Rontime (07-20-2017)
Let us not forget about the infamous rear end fluid change. If theres one thing that smells worse than mildew it's rear end grease....at least the old stuff.....PEWWWWWWWEY......
Suicide?
