76 rear spring
Cruising
76 rear spring
I have a 76 the rear spring rubs on the drivers side tire, when you turn right,, has the spring lost its arch?what is the stock clearance? its a 9 leaf, thanks for the help. any good mechanic in Rochester ny??
It goes without saying, that should not be possible. Even un-arched, it should not make contact. It could be sliding in the rear differential brackets. I wonder if the center pin sheered somehow?
Received 2,878 Likes
Cruising
thanks,the spring end rubs on the wheel, the wheel weights hit, I will try to post pics,
a loose camber adjustment nut could cause the wheel camber to change while going through a turn. Looking at the drivers side tire from the rear how would you describe the tire straight up and down, or the top of the tire learns in towards the body?
Are the camber adjustment bolts tight?
What size are the tires?
