[Z06] Alignment problem
Alignment problem
Hey so when i did my cam swap i noticed both tie rod ends were bad so i swapped them out and brought the car for an alignment but everytime he would get the car straight and test, the alignment would shift. We checked all bushing, ball joints, end links all of it and theres no play in the front end. I noticed my front cradle has a gap between the cradle and frame. I took a video i was wondering if this was normal as i never touched the cradle during my cam swap.
The video quality isnt very good but you cam see the gap.
thanks
thanks
Yea we tried to loosen the rear bolts on the cradle jack the pan a little bit and tighten the front ones but no luck...i wonder if i have to drop the suspension, a arms, loosen the motor mounts to get some play? I never noticed the gap until then so i am not sure...im guessing that gap isnt normal though?
I have dropped the front and tightened back with no effort, Same for the back....Weird
Take the bolt all the way out and make sure it's not damaged, stripped.
Yea it is weird i think i will try again tommorow jack the cradle and pull the bolts out and see how they look if not i guess il have to try to drop the suspension...all i can think of is mayby the dowels are bent from not being seated and causing it to bind? I have no clue
Yea my alignment is way off because i pulled rack and changed both tie rod ends during cam swap and ya there are 2 dowels that lign up the cradle i attached a pic. Thats all i can think of.
Does anyone have any pics of there cradle sitting flush with the frame or know if this is abnormal? I have been searching and found another pic online where the cradle has the same gap as mine...
Yea i just changed tie rod ends when i had the rack out for my cam swap, thats why i went to get it aligned, and inners have no play either...im juat curious about why i have that gap between the cradle and the frame? Does anyone have pics of theres bolted to the car to see if theres a gap like mine, everything seems tight i cant figure it out
I bought the car with headers already on it im wondering if they lowered the cradle to install the headers and never reinstalled it correctly? But if i had the car on the alignment lift and jack the pan up and tried loosening rear cradle bolts and tightening the front they wouldbt budge? Do you think i have to loosen motor mounts, upper tables and remove shock i would get more play in it to get it flush?
