2017 Grand Sport dealer messed up rocker
Hi all,
Took my GS in to the dealer to find out why the drivers seat cooling/heating is not working at all and they messed my rocker extension up. It appears like they hit it with the lift arm. I also had them clear filmed and Opticoat Pro + ceramic coated before this, so they will be paying an additional 450.00 to refilm and ceramic the rocker(whether they like it or not). They have ordered another one and I want to know what all is involved in replacing this?
I have heard that the extensions are riveted into the fiberglass rocker, so I am worried about an incompetent tech drilling the rivet holes too big and not getting a good fit? Maybe I am worrying too much, but would like some advice or ideas on what to expect/look for when they replace this. I expect nothing short of perfection so I am hoping they make it right. Below is picture of the damage
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
It was a mistake. I'm sure the dealership will take care of this for you. They have owned up to the problem-I'm sure they will make it right.
Really? That sounds like a good idea, but I would be worried about the film withbthem having to drill/rivet. Ill call the detail shop and see what he thinks. I appreciate the idea though!
Should be an easy fix for a halfway decent mechanic. Some care is needed to drill out the rivets, and there are also a couple of screws. I wouldnt worry.
Poppacapp (07-27-2017)
seems like a good opportunity to get full length side skirts
It will be an easy fix. A performance shop damaged one of mine. I drilled out the rivets, took it to be repaired and then riveted it back on. Like anything, as long as they're careful and take their time it will go smoothly.
I like the skirts that are on there now.... Just not so much with the damage
Thanks for the info. I am hoping they are more careful replace this than the last time working on the car
Received 8,928 Likes
Thanks for the info. I think I'll ask to talk with the tech who will be doing the repair and ask him his plan of action. I just want to make sure the rivets are not drilled out too large(hole wise)
First rule is: Don't be an A$$Hole Corvette owner.
Bill
Gotcha. Dropped the car off today for them to replace it. Hopefully all goes well. Hopefully there are no more "mistakes" from this dealer.
