Brake Bundles packed with 25% savings @ RDP Store...........
Supporting Vendor
Brake Packages available at RDP Store for you Corvette. Brake pad packages front and rear, Pad and Rotor Packages, Stainless Braided Brake line packages and more. Save huge money with our bundles vs buying individually. If you do not see the combo you want in any of our bundles on our online store. Let us know we will assemble you one with the performance you want and savings to boot, but you you do not know what is best for your driving style contact us and we will help you choose. We have 30 plus years of road racing and performance street car building under our belts. You can reach out to us at anytime 7 days a week through phone (440)358-5500 or email sales@rdpstore.com or PM us here on the forum.
http://www.rdpstore.com/c-127-brakes.aspx
Supporting Vendor
RDP Store has put together a great and proven track day brake upgrade for you Z51 equipped Stingray. With DBA, Hawk and Stop Tech. This package is proven to make your C& faster around the track and safer too.
http://www.rdpstore.com/p-8741-2014-...4000-frts.aspx
T3 4000 Series Rotors are DBA’s most advanced one-piece brake rotor on the market. These rotors are designed to perform in extreme road and race applications.
DBA 2013+ Chevrolet Corvette C7 - Base / Z51 Rear T3 4000 Series
HAWK StreetRace Brake Pad Set
The use of street cars in racing is a trend that increases every year, and drivers are constantly demanding more. They are always looking for an edge over the competition.
Using decades of engineering data from our racing programs, the Hawk Performance team cross-engineered the new Street/Race compound. This new compound is the ultimate high-performance, street brake pad — perfect for performance drivers who use their street cars for autocross, HPDE, open track and time-trail racing. High-Performance Street/Race pads feature Hawk’s Mechanical bond Retention System (MRS), slotted friction, hot-bond shim and pad chamfer, which improve vehicle handling, driver confidence and overall safety. It performs flawlessly at operating temperatures between 100 and 1200 degrees Fahrenheit, oering superior torque and providing consistent braking characteristics and great pedal feel.
*Features:*
* Contollable torque
* Great rotor & pad wear life
* 100-1200°F operating temperatures
* Smooth feel and bite
* Excellent brake rotor wear
* Consistent brake release characteristics
* *Optimal Range:* 100° - 800°
* *Min/Max Temp:* 100° - 120°
* *Torque:* Medium
Improve vehicle brake performance and feel with Stoptech Stainless Steel Braided Brake Lines.
Stoptech Stainless Steel Braided Brake Lines provide a quicker, firmer, more consistent pedal response by maintaining consistent brake pressure. Additionally, stainless steel lines provide precision brake modulation, especially during threshold braking. The improvement in pedal feel is more dramatic on older vehicles where the factory rubber line may have softened and swelled due to age.
StopTech brake lines consist of a PTFE (commonly referred to as Teflon) inner line that carries the brake fluid, which is then covered with a layer of stainless steel woven braid. The PTFE tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid.
The braided stainless steel provides support for the PTFE and the weave is extremely durable against incidental impact and abrasion. Next the stainless braided hose is coated with a clear abrasion resistant PVC cover for maximum protection against chaffing and strain relief devices reinforce end fittings.
A variety of end fittings are available to meet most application needs. All fittings are engineered for proper fit and durability. All necessary brackets and fasteners are included with each line kit.
*Coated Teflon inner core*
StopTech brake lines consist of a PTFE (commonly referred to as Teflon) inner line that carries the brake fluid, which is then covered with a layer of stainless steel woven braid. The PTFE tube is very resistant to expansion under pressure and maintains integrity with exposure to corrosive brake fluid.
*Stoptech braided brake lines protect against the elements of harsh driving conditions.*
The stainless steel braid provides support for the PTFE and the weave is extremely durable against incidental impact and abrasion. Next the stainless braided hose is coated with a clear abrasion resistant PVC cover for maximum protection against chaffing and strain relief devices reinforce end fittings.
*Testing beyond the limit is our quality assurance*
Every StopTech brake line is 100% tested in-house to a pressure of 4,500 PSI. This is almost 4 times the typical line pressure exerted by a production vehicle's master cylinder.
StopTech is a registered brake line manufacturer with the United States DOT and all StopTech Stainless Steel Brake Lines are manufactured to meet DOT Compliance Standards. StopTech Stainless Steel lines also meet or exceed FMVSS 106 and applicable international and EU standards.
Motul Brake Fluid sold separately
*Features:*
* *Torque:* Medium
Supporting Vendor
Looking for an upgrade pad slap on you Z51 equipped Stingray that will see some street and track duty. Check out this RDP Store combo of Hawk Street/Race Pads.The use of street cars in racing is a trend that increases every year, and drivers are constantly demanding more. They are always looking for an edge over the competition.
*Features:*
* *Torque:* Medium
http://www.rdpstore.com/p-9492-hawk-...hb727r592.aspx
*Features:*
* *Torque:* Medium
Supporting Vendor
Low Brake dust brake pad option now at RDP Store. EBC Red Stuff is our workshop go to for the customer that is happy with the OE pad performance but hates the dust. The EBC Red Stuff is the pad we turn to for low dust and a 15% torque advantage over OE, so gain some performance and kill that brake dust.
http://www.rdpstore.com/p-10144-2015...-redstuff.aspx
Supporting Vendor
Labor Day Huge Savings Weekend on All Products at RDP Store
Wether your Looking for a
Supercharger
Header and Exhaust Package
Cold Air System
Programmers
Driveline Products
Suspension
Fuel Systems
Gauges
Floor Mats
Brakes
And Much Much More !!!!!!!!!!!!
Simple Just Choose the Item your Looking at and PM us the Part Number and we will send you over a Promo Code and Everything Ships for FREE !!!
Supercharger
Cold Air System
Programmers
Driveline Products
Suspension
Fuel Systems
Gauges
Floor Mats
Brakes
Supporting Vendor
Improve vehicle brake performance and feel with DOT-Approved Stoptech® Stainless Steel Braided Brake Lines.
Stoptech® Stainless Steel Braided Brake Lines provide a quicker, firmer, more consistent pedal response by maintaining consistent brake pressure. Additionally, stainless steel lines provide precision brake modulation, especially during threshold braking. The improvement in pedal feel is more dramatic on older vehicles where the factory rubber line may have softened and swelled due to age.
StopTech® brake lines consist of a PTFE (commonly referred to as Teflon®) inner line that carries the brake fluid, which is then covered with a layer of stainless steel woven braid. The PTFE tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid.
Shop Now at RDP Store, StopTech front and rear bundles now available
http://www.rdpstore.com/c-3114-stoptech.aspx
Supporting Vendor
Specials still running
Supporting Vendor
At RDP Store we Strive to do what the others Fail to do, We communicate with you our Customers Before During and After order, we stock a huge range of parts and if we dont have something in stock and have to drop ship or back order we will let you know immediately and see what you wish to do and keep you up to date, and we will not allow you our loyal customers to wait weeks and even months on your items as many of you have experienced with other vendors. Also as most of our Customer know we not only run the Business Phone lines from 7am to 6pm but we also offer Dynosteves Cell Number 440 251 8571 for Customers needing help or information after hours.
RDP Store Policy
Best Pricing
Best Service
Best Communication
Fast Replies to PM's and Phone Calls 7 Days a Week and and Past Business Hours
Free Shipping to the Lower 48 States
Cost Price Shipping anywhere else in the World
Price Matching
Technical and Tuning Support on the Products that we sell. (we not only sell performance parts but we install them and dyno tune them in house)
Fully Up to Date Online Store with Tracking Information
We Help with Tech Support for Customers even on items we didnt sell.
Thankyou for your Business and Continued Support of RDP Store and we look forward to helping and working with you all in the Future.
RDP Store Policy
Best Pricing
Best Service
Best Communication
Price Matching
Supporting Vendor
RDP Store wont be beaten on pricing and service to all our forum member friends here, pm us for a price with free shipping to your door.
Supporting Vendor
Winter time is knocking on the door, so where did your Corvette brakes let you down this year? Contact RDP Store to discuss your brake options today.
Supporting Vendor
At RDP Store you simply Find it Choose it and Save, Simply search our online Store at www.rdpstore.com find the part your looking for, put it in your shopping cart and pm us for a promo code and we will make you a deal to blow the others away. Top this off with Free Shipping to the Lower 48 States and Cost Price Shipping anywhere else in the World and your on the Way to Huge Savings and Great Performance Parts, pm us here for more details or give us a call on 440 358 5500 or 440 251 8571
