Kook Headers & X-pipe Install Help
Old 07-25-2017, 05:03 AM
Chazzmania
Chazzmania's Avatar
Default Kook Headers & X-pipe Install Help
Hi Guys,
Hopefully this is the correct place to post this. I purchases some Kook LT Headers along with the green X-pipe. I received a quote from a local shop here in Hawaii for possibly 600-650 to install them. I am thinking about trying to do this myself. I don't have a lift and the car will be on jack stands. I have seen many post about the challenges people have with the small area under the car to work. I would like any opinions people might have on doing this install myself. Any pics or videos of someone doing this would be great. Any foreseen issues that could come up doing the install. These will be going on a 2016 C7 Z51.
Old 07-25-2017, 01:14 PM
konqueror5
konqueror5's Avatar
https://www.corvetteforum.com/forums...r-install.html
Old 07-25-2017, 06:24 PM
Chazzmania
Chazzmania's Avatar
Thanks for this. Hopefully it's as simple as the instructions.
Old 07-27-2017, 04:00 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
I would see if it was me if I could rent a 4 post lift r 2 post lift from a person are some kind of shop close by are a garage. it will not take you over 3 hours are that is what it took me to do mine on the car.
Now if you are a young guy a lot has done it like you have said. But that is why I went out and got me a 4 post lift & put in my garage. Just to old to do it any more on my back & up and down so much It would have taking me all day to do it like that. Robert
Chazzmania (07-28-2017)
Old 07-28-2017, 05:06 AM
Chazzmania
Chazzmania's Avatar
Rob did you have to remove xtra like the directions in the above post stated? Where you able to do everything from the bottom of the car? Any other tips would be greatly appreciated.
Old 07-30-2017, 06:47 PM
lakemg
lakemg's Avatar
Here's a reasonable video with some pointers:
On edit: I don't remember needing to remove the starter to get the Kooks installed, so you should be good too. Mine is a 2015 Z51.
I did mine using race ramps in the front and some wooden blocks to keep the rear off the ground along with multiple jack stands to keep things safe. It was still low enough in the front to access components in the engine compartment:
Old 07-30-2017, 08:01 PM
uneedthis2
uneedthis2's Avatar
Anybody with input around having to disconnect the lines to the dry sump? When you disconnect them, do you need to be prepared to catch a bunch of oil?
Old 07-30-2017, 08:13 PM
lakemg
lakemg's Avatar
If you drain the oil out of the pan first, then pull the lines, not a whole lot of oil comes out from what I recall.
Old 09-02-2017, 09:57 AM
Chazzmania
Chazzmania's Avatar
Bump
Old 09-02-2017, 10:58 PM
lakemg
lakemg's Avatar
Hey buddy, have you started the install yet?
Old 09-02-2017, 11:26 PM
Chazzmania
Chazzmania's Avatar
Hey man, I plan to start in two weeks. All the parts should be here this week. Just need to pick up the swivel sockets. I am having my mirrors wrapping and the chrome strip on the front bumper wrapped next weekend. After that's done imma start the Install. Hopefully I can get it done in a day.
Old 09-02-2017, 11:32 PM
lakemg
lakemg's Avatar
Awesome!!! Sounds like a good plan.
Old 09-03-2017, 12:36 AM
Chazzmania
Chazzmania's Avatar
Do you mind pm your number just in case in run into any issues I could shoot you a text?
Old 09-03-2017, 01:32 AM
tuboy19
tuboy19's Avatar
FYI Kooks do not require the lines to be removed to install the headers
Old 09-08-2017, 08:41 AM
vtmike24
vtmike24's Avatar
May not be required, but it definitely makes it easier. It is not hard to do. Just drain your oil from the two drain plugs like normal, then take out the two(?) bolts for the flange on each line. It takes a bit of effort to pull the lines out of the sump since they are fairly stiff and the are inserted about 3/4" into the sump. A good amount of oil will come out, so be prepared. I just zip tied a rag to the end of the lines to prevent them from dripping all over the place while I worked.
Old 09-08-2017, 10:53 PM
brettmess24
brettmess24's Avatar
I had to remove mine to get my kooks headers on. Took me almost eight hours for the headers and Halltech CAI everything fought me on this install but damn is it worth it
I actually ended up cutting my passenger side cats in order to get them out. I had no way to access two of the four bolts that connect the cats to the manifold. That and getting the kooks cats just right took me the longest.
Good luck man, Ill check in here when you do the install.
Old 09-09-2017, 09:56 AM
vtmike24
vtmike24's Avatar
I had a hell of a time with those bolts too. I spent the majority of my time figuring out how to get those off using a combination of deep sockets, regular sockets, breaker bar, and an open end wrench. I ended up hitting one of those tools with a rubber mallet to break the bolts loose. I can't remember which lol.
To Kook Headers & X-pipe Install Help
Old 09-14-2017, 07:45 AM
Chazzmania
Chazzmania's Avatar
Thanks for all the tips guys. I am excited about getting these on. When my wrap is finished up I will start the install.
Old 09-14-2017, 11:06 PM
brettmess24
Finished wiring up my AEM wideband monitor tonight
And purchased a katech ptb might as well put that on too😂
Are you going to tune it or hope for the best?
my iPhone pictures during install
Old 09-15-2017, 04:12 AM
Chazzmania
Chazzmania's Avatar
As of now I don't plan on getting a tune. Trying to keep the warranty a little bit longer. I will be running the LTs with the green cats, so fingers crossed I don't need anything special.
Quick Reply: Kook Headers & X-pipe Install Help
