Sponsored by: GEM Motorsports
Long tube header rattle video inside
Old 07-25-2017, 10:14 AM
charles7970
charles7970's Avatar
Default Long tube header rattle video inside
just curious if this is normal after a header install 😕
Old 07-25-2017, 10:42 AM
Corvette4ever
Corvette4ever's Avatar
This can't be normal
Old 07-25-2017, 11:18 AM
charles7970
My installer told me it was
Old 07-25-2017, 11:51 AM
musclesbmf
musclesbmf's Avatar
sounds like they are rubbing the tunnel somewhere and it's vibrating. Hard to hear in video. On one set of mine on a c6 Z06, had to loosen the motor mounts and shift the engine a bit on one side with a pry bar to give enough clearance and then re-tighten the motor mounts.
Old 07-25-2017, 12:56 PM
h3mpking
h3mpking's Avatar
I did not have that after my header install, but my buddy did after he had some engine work and headers reinstalled. The exhaust is vibrating and hitting something. Remove the tunnel plate and wiggle the exhaust to see where it is hitting and make adjustments as necessary.
Old 07-25-2017, 01:01 PM
charles7970
Will do and thank you for the recommendations! Luckily its not a daily lol
Old 07-25-2017, 05:17 PM
h3mpking
h3mpking's Avatar
Should be an easy fix.
Old 07-25-2017, 05:23 PM
3 Z06ZR1
3 Z06ZR1's Avatar
I have headers and they are like stock exhaust no rattles no issues but they run cooler esp with the Jethot coating. They are louder in sport an track mode but in touring they just sound better tan stock more tunes but no much if any louder.
So you have an issue.
Old 07-26-2017, 02:45 AM
Xearian
Xearian's Avatar
After installing headers on my Z06, there was a loud rattle through my dash board. The installer said it was normal but when I took it to get tuned, that shop said it shouldn't be rattling like that and fixed it as the headers were rubbing against something in the engine bay.
Old 07-26-2017, 05:23 PM
FF_Z06
FF_Z06's Avatar
What brand of headers? I have Kooks LTs...no such rattle here
To Long tube header rattle video inside
Quick Reply: Long tube header rattle video inside
