Black Drilled/Slotted Rotor PICTURES Please
So I am in the market for rotors and pads (Brakemotive is the way I am probably going) and I saw they have black zinc coated rotors. I have seen tons of reviews about the standard silver colored ones as well as pictures, but I cannot for the life of me find pictures of the black rotors WITH THE WHEELS ON. I don't care how they look mounted on the hub... I can use my imagination for that. I am curious to see if I may like the black ones more than the regulars before I pull the trigger and purchase anything.
Received 3,812 Likes
St. Jude Donor '03-'04
No such thing as black rotors. any coating on the fire path will be removed buy the pads.. however if you have 15 grand you can get some Cf composite rotors they are almost black.
You can get rotors with black Hats, but not the actual contact path.
http://www.ebay.com/itm/401156781302
These considered black "hats"? The black gets wore off when the pads are applied?
Good Luck
Bill aka ET
You didn't take the time to read the description? It says Black coating will be removed from the area in contact with the pads leaving the silver rotor. I'm not sure of the quality of these rotors but its a good idea to have everything coated to avoid as much rust as possible... However, the area in contact with the pads where the raw cast iron is exposed will rust immediately on contact with water. The rust will be removed on the next few cycles of brake engagement.
Good Luck
Bill aka ET
Good Luck
Bill aka ET
here is a photo of my Baer Eradispeed rotors when I got them 80,000 miles ago and 14 years ago.
here is a photo of them today 14 years later with 80,000 miles on them.
Hope this helps you
Bill aka ET
I understand all that. I was wondering how the black rotors (even with the face of them not black) look behind a wheel.
Basically, the second "after" picture - I want to see that with wheels around it on a corvette..
mike48750 (07-26-2017)
Evil-Twin (07-26-2017)
Bill aka ET
Received 19,293 Likes
'20-'21-'22-'23-'24
A rotor with black hats will look good on the car, the real issue is the quality of the rotor itself.
No track time but My Baer Drilled and slotted rotors are 14 years old and have 80,000 miles on them, No cracks. Baer sells lots of these 2 piece light weight high quality Australian cast iron with no fillers. but they are 1500 dollars not 200 dollars and we are not as dumb as we look... years of early life experience buying cheap stuff has brought me to the conclusion that I can not afford to buy anything that is cheap. It just cost too much. Most track members use cheap NAPA throw away rotors 50 dollars a piece. Last two or three track days, depending on events.
Received 1,224 Likes
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Modified
I bought the Brakemotive package. I painted and cleared the hats myself. It's only been a few hundred miles and a few months. So far, so good.
Thank you for the several different pictures everyone. They look nice, but not different enough in my opinion to spend $20ish extra for a little black hat on the rotor. If I decide later on that I want that black color to brake it up a little bit, I will probably do what BAT did.
I don't plan on taking my car to the track, I'm just on the street. And from what I've read, the Brakemotive packs are sufficient, especially for the price. I wouldn't expect this package deal to last long on the track, by any means lol.
As they came:
painted hat:
