Has anybody replaced their steering wheel?
Hi All,
I'm contemplating replacing my steering wheel with another OEM but in suede... has anybody replaced their steering wheel ? any concerns with the air bag ? electric connections ? anything to consider ?
Thank you in advance !
Dan
Dan
Swapping out the steering wheel is a fairly popular project. No real issues with the airbag as long as you take the proper precautions. Some members reported the steering wheel nut was challenging to get loose. But others come off with no issues. Look here for more info.... https://www.corvetteforum.com/forums...-swap-diy.html
Received 7,753 Likes
CORVETTE TODAY Host
St. Jude Donor'15
...or you can do this.
Am I correct to assume you did that without removing your steering wheel ? I am actually preferring the Suede texture to the leather
Last edited by Steve Garrett; 07-26-2017 at 09:29 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make your reply look like this.
Why not this? The center bolt is a pain to remove try heat gun to melt the locktite. Use a long breaker bar.
Attachment 48117655
Attachment 48117655
ZorenZ51 (07-26-2017)
Attachment 48117655
Attachment 48117655
http://henkeladhesivesna.com/blog/ho...-threadlocker/
CORVETTE TODAY Host
St. Jude Donor'15
Mine was a full steering wheel swap-out. As you can see, the paddle shifters and steering column buttons are also in Carbon Fiber. The dealership did the swap out for me.
I was going to replace the shifter with the suede too, but then I ordered the MGW shifter which should be here shortly and also ordered a black shifter **** with the red evil smile.
I also wanted to swap out the console for a carbon fiber one, but I'm having a tough time justifying the 300-400 for what looks like a carbon fiber wrap over plastic
Steering wheel swap
I did exactly what you intend to do
Center nut is tough but a good heavy Breaker Bar made it easy.
Make sure you disconnect the battery and discharge the system FIRST!
Just step on the brake a bunch of times after the battery disconnect to use up any lingering power in the system.
Good luck
Good luck
dbintegrity (07-27-2017)
Looks great ! so does the boot ! Why did you switch ? looks or for feel ? I like the looks of my steering wheel but I felt the leather was sort of slippery, thus considering swapping it out for the suede...is there a noticeable difference? I ordered the MGW shifter because with the original, I found it too easy to miss the gate at 4 to 5 and 6 to 7..
Dan
Dan
Received 2,373 Likes
ZorenZ51 (07-27-2017)
Steven Bell, where did you get your steering wheel?
