What is the true cause of headlight lenses going bad? How to prevent?
So I have been searching to find out why the C6 headlights go bad, fog, craze up, etc.
Mine are perfect and I want to keep them that way but I haven't been able to figure out what the cause and prevention of the issue is.
I read this on the Lamin-X site the other day...
Has any true cause been determined?
***DISCLAIMER:THE C6 CORVETTE HAS EXTREMELY SENSITIVE HEADLIGHT LENSES THAT ARE HIGHLY PRONE TO CRACKING. GM RECOMMENDS AGAINST COVERING THE LENSES WITH ANY MATERIAL DUE TO POTENTIAL CRACKING ISSUES.
Received 1,596 Likes
My best guess would be that covering them would help with UV damage, but then when the lights are on the covering would trap the heat generated by the lights leading to damage. So best bet would be covers during the day, no covers at night. Kind of like pop up headlights............
UV and plastics do not get along! Worked for a injection molding company and we added a UV inhibitor but it just slowed the process never eliminated it. I keep car in garage most of the time and clean all lenses with Plexus
The only way to slow the process is to park in a dark garage.. My 2005 lens look almost new, but I'm sure they won't last that well with me owning the car..The problem is , I like to take the car out and drive it.......WW
I've had my C6 for ten years now and the lenses are just starting to craze a bit. They're not fogging up, but, have some tiny little lines on the inside. My Vette has been garaged for half its life.
My 2008 Silverado's headlight lenses are perfectly clear and uncrazed. It has never been garaged. It's always outside in the sun, rain, snow, ice. I can't figure that one out!
my C6 was pretty much a garage queen until I got it, both lenses are crazed, no fogging or any other issue, will eventually replace them with one of the aftermarket brands
Use.
If you don't want them to wear out, don't drive the car and leave it covered in a garage. Road debris, sun, etc will slowly wear them out. Just plan on replacing them every ~7-12 years. Not a big deal.
Mine are ~11 years old and starting to show cracks, etc.
NC Events Coordinator
I have an old 2005 Nissan Altima 3.5 SE that is my DD. Considering where I have to park it sometimes, it's the perfect vehicle. I bought it new, but it's been sitting outside since I bought my first Corvette 7-8 years ago. It's been a super-reliable car and over the years the original headlight covers have held up pretty well.
I hit a deer about 5 years ago, and unbeknownst to me, the body shop replaced the one broken headlight with an aftermarket part. Fast forward to this summer and the affected headlight cover is now yellowed significantly. This is something that the usual polishing routine won't fix. I polished both lenses and the aftermarket one looks like *** while the original looks good as new. Same with the lenses on our van. They look great.
Lesson learned. If you get collision work done on a car, insist on 100% manufacturers' parts. That aftermarket crap is cheap for a reason.
“Whenever any malfunction occurs in a component that controls or conducts power for the actuation of the concealment device, each closed headlamp concealment device shall be capable of being fully opened by a means not requiring the use of any tools. Thereafter, the headlamp concealment device must remain fully opened until intentionally closed.”
The NHTSA requires that there is a manual way of opening the headlights if the powered system fails:
They are all but banned in the EU so if you're intending to export or co-produce cars for the European market and the U.S., you'd need to design entirely different front ends.
I think my wonderful c5 had a manual **** for cranking open the headlight door. so that probably fixed any issues with the regulatory agencies.
Supporting Vendor
manufacturers combat this with a UV treatment (usually a spray-on) that will last about 3-5 years depending on sun exposure. This UV can also come from florescent lights of a garage as well.
As a the designer of the C5 fixed headlights known as the "stealth light cannons" I found that using a UV stable Impact Modified Acrylic offers substantial resistance against sunlight as well as a fair balance between impact and scratch resistance.
