LED Switchback
gordosoar (07-29-2017)
Anyone ever try these??
http://www.ebay.com/itm/Switchback-3...4Y7cvA&vxp=mtr
JDM ASTAR Extremely Bright 3030 Chipsets White/Yellow 3157 3155 3457 4157 Switchback LED Bulbs with Projector For Turn Signal Lights(Brightest Switchback bulb on the market)
They don't come with the resistors (which I ordered) but the hyperflash is minimal so I did not install the resistors.
bartsky , not sure what your price point is but they coolest looking LED switch backs are RADIOFLYER Innovations switchbacks and harness
http://shop.radioflyerinnovations.co...rvette-089.htm
They are a vendor on this forum
this type of switchback bulb that you are looking at only turns white at night when your headlights are on then turn amber when you put the turn signals on or when driving during the day
if you want to spend a bit more money , radio flyer sells a harness and the BEST and brightest bulbs , these stay white no matter if the headlights are on or not and only turn amber when you turn on the turn signals
the harness uses GM connectors , has the resistor to stop hyper flash built in and is a real quality piece , the bulbs are best in class not some junky import
They look so cool during the day and I get a ton of complements on them
With just the lights on ....
and with the left turn signal on
Dave
Dave
CaPilotMark (07-27-2017)
Thanks for the reply. Yes he seems to have the best quality as I have ordered from him before. I trade cars very often, so I am going to give these cheapies a shot. I have cree led reverse lights that I have swapped into countless C6's, and they are still going...
I have both the led switchback bulbs and the harness...
Just gotta find time to install them.
Love the look of white lights while driving; yellow when the turn signal is engaged.
IMO it's insane there's no way to simply permanently disable the DRL function. If not an onboard menu item, then at least doable through software. I've trained myself to twist the switch on the turn sigs every time I start the car, but it's a kludge and I occasionally forget. Seriously, in daytime a bright-red Vette is just as noticeable without those dingy amber lights.
I use these & very happy with them at a reasonable price.
Alla Lighting Newest 4014 62-SMD Super Bright 3157 4157NA T25 LED Switchback Bulbs Dual Color White Yellow Lamps Replacement for Turn Signal Blinker Light (3157/T25)
found at Amazon
found at Amazon
I was doing research on capabilities of Tech2 scanner and it may be possible to reprogram the BCM removing the T62 RPO code (Daytime Running Light - Delete). DRL's as a removable option in the BCM was required for certain non-US markets where yellow DRL's are not permitted.
I know the T62 RPO is listed as an available option on C6's up to 2010 but I won't be able to confirm it is available in my 2011 Grandsport until I get home. The 2011 RPO code listing I found online does not include the T62 code but that may only be indicative that GM did not permit you to order a US spec C6 without that code.
I will check with my Tech2 this weekend ...
Funny you should say that.
let us know what u find
Dave
Wait so you're saying if I get a Tech2 clone I could remove an asterisk next to DRL and be done with the blasted things? I've been on the fence about getting the clone, wondering if I'd find enough use for it, but that might be compelling enough to get one.
just removed the magnetic shock option for a friend of mine last week ....as easy as unchecking the option and uploading
also programmed some key fobs for another
I love my TECH ll..
Well, checked BCM programming options using my Tech2 on my 2011 Grandsport and I don't see any reference to DRL under options.
I did go ahead and activate the "Afterblow" option on the A/C system though.
